LSYRUR 1 Posted November 16, 2022 Posted November 16, 2022 Latest QTS version, Emby version 4.7.8, qpkg, premier enabled. The video got stuck, CPU to 90%, memory usage from 75% (totally 8g) to 90%. The log is attached. Please help me to fix it, thank you. ffmpeg-transcode-39c9c157-6ff5-4aeb-ad76-8cb09b10b4da_1.txt
LSYRUR 1 Posted November 16, 2022 Author Posted November 16, 2022 And there is a new version of TS-464C. My 464C has a CPU of N5095 instead of N5105.
Happy2Play 9811 Posted November 16, 2022 Posted November 16, 2022 Devs will have to comment on why HWA failed, but falling back to Software and can't process fast enough do to HEVC conversion and PGSUB subs. 09:40:35.714 Error while decoding stream #0:0: Cannot allocate memory 09:40:35.714 [hevc @ 0x7f6d7c0341c0] get_buffer() failed 09:40:35.714 [hevc @ 0x7f6d7c0341c0] thread_get_buffer() failed 09:40:35.714 [hevc @ 0x7f6d7c0341c0] Error parsing NAL unit #0. 09:40:35.720 subtitle_kickoff: call subtitle_resend_current 5015 frame->format: 1 09:40:35.721 subtitle input filter: decoding size 0x0 09:40:35.721 Auto-inserting subfeed filter 09:40:35.721 Auto-inserting graphicsub2video filter *** Error in `/share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg': corrupted double-linked list: 0x00007f6d7c0f2b50 *** Can you update to current release 4.7.9.0?
LSYRUR 1 Posted November 16, 2022 Author Posted November 16, 2022 51 minutes ago, Happy2Play said: Devs will have to comment on why HWA failed, but falling back to Software and can't process fast enough do to HEVC conversion and PGSUB subs. 09:40:35.714 Error while decoding stream #0:0: Cannot allocate memory 09:40:35.714 [hevc @ 0x7f6d7c0341c0] get_buffer() failed 09:40:35.714 [hevc @ 0x7f6d7c0341c0] thread_get_buffer() failed 09:40:35.714 [hevc @ 0x7f6d7c0341c0] Error parsing NAL unit #0. 09:40:35.720 subtitle_kickoff: call subtitle_resend_current 5015 frame->format: 1 09:40:35.721 subtitle input filter: decoding size 0x0 09:40:35.721 Auto-inserting subfeed filter 09:40:35.721 Auto-inserting graphicsub2video filter *** Error in `/share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg': corrupted double-linked list: 0x00007f6d7c0f2b50 *** Can you update to current release 4.7.9.0? updated to 4.7.9.0, problem still there.
LSYRUR 1 Posted November 16, 2022 Author Posted November 16, 2022 log in 4.7.9 ffmpeg-transcode-84b01e98-c581-41bd-9e15-d3ded181f531_1.txt
Luke 42239 Posted November 20, 2022 Posted November 20, 2022 Hi, are you able to try the 4.8 beta channel and let us know how that compares? Thanks.
Happy2Play 9811 Posted November 21, 2022 Posted November 21, 2022 I would question this *** Error in `/share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg': corrupted double-linked list: 0x00007f6d7c0f2b50 *** Not positive if they are the same issue but may be issue mentioned here.
LSYRUR 1 Posted November 22, 2022 Author Posted November 22, 2022 hi, tried 4.8, problem fixed. thank you. 1
