aperoid 0 Posted November 11, 2022 Posted November 11, 2022 it happened Update App automatically. it can see only in the App playing. AndroidTV and Web version is okay. plz fixed it. i bought Emby Premiere with "Life Time". whats the problem?? Every a vowel & a consonant Fractured, Cracked. it has to be combined.
Luke 42243 Posted November 15, 2022 Posted November 15, 2022 Hi, I apologize for the issue. We are aware and are looking into it. Thanks.
dgdfherthfh26 3 Posted November 24, 2022 Posted November 24, 2022 This is serious problem for korean. do we have to wait for 18 months like this problem?
manatails 2 Posted November 27, 2022 Posted November 27, 2022 version 3.2.77 doesn't have this problem. The new font introduced in 3.2.82 breaks it. By the way, is there a chance that Emby will get custom font settings? It'd be much easier to handle such problems if we just had the ability to use alternative fonts
Luke 42243 Posted November 28, 2022 Posted November 28, 2022 23 hours ago, manatails said: version 3.2.77 doesn't have this problem. The new font introduced in 3.2.82 breaks it. By the way, is there a chance that Emby will get custom font settings? It'd be much easier to handle such problems if we just had the ability to use alternative fonts It is certainly possible, but we should still have a good out of box experience.
intel329 6 Posted December 9, 2022 Posted December 9, 2022 On 11/28/2022 at 12:16 PM, Luke said: version 3.2.77 doesn't have this problem. The new font introduced in 3.2.82 breaks it. Can't I roll back to the previous version? It is difficult for Android users to use the app due to this update (Emby for Android 3.2.82).. i can't watch movies or TV shows that require subtitles at all.......
Luke 42243 Posted December 9, 2022 Posted December 9, 2022 11 minutes ago, intel329 said: Can't I roll back to the previous version? It is difficult for Android users to use the app due to this update (Emby for Android 3.2.82).. i can't watch movies or TV shows that require subtitles at all....... Hi, are you having a problem with Korean subtitles?
intel329 6 Posted December 9, 2022 Posted December 9, 2022 There's a problem. In Emby for Android 3.2.82, Korean subtitles appear as pictures (Above: Wrong , Below: Correct). For example) "향기를 향수처럼" is right, It comes out wrong as "ㅎ ㅑ ㅇ ㄱ ㅣ ㄹ ㅡ ㄹ ㅎ ㅑ ㅇ ㅅ ㅜ ㅊ ㅓ ㄹ ㅓ ㅁ" The letters don't come together, they come out separately. Recently, a problem appeared in a version that included a font update(Maybe Android 3.2.82). Please fix it quickly. Many Koreans are suffering from this problem.
dgdfherthfh26 3 Posted December 9, 2022 Posted December 9, 2022 4 hours ago, Luke said: Hi, are you having a problem with Korean subtitles? It's been a month and you didn't know about this prob? i told u this is serious prob for Korean. On 11/15/2022 at 1:09 AM, Luke said: Hi, I apologize for the issue. We are aware and are looking into it. Thanks. even you answered this prob, but now u forgot this prob? lol
intel329 6 Posted December 22, 2022 Posted December 22, 2022 On 2022. 12. 9. at 오전 10시 17분, Luke said: 안녕하세요, 한국어 자막에 문제가 있습니까? Due to this issue, Emby is useless on my mobile phone after version 3.2.82. Instead of waiting until the next version. It needs to be corrected immediately with a hot fix. It's a huge loss for subscribers.
dgdfherthfh26 3 Posted December 23, 2022 Posted December 23, 2022 On 12/22/2022 at 2:11 AM, intel329 said: Due to this issue, Emby is useless on my mobile phone after version 3.2.82. Instead of waiting until the next version. It needs to be corrected immediately with a hot fix. It's a huge loss for subscribers. 3.2.77로 다운그레이드 하세요. 얘네 믿다간 위의 사례처럼 1년 이상 걸릴 것 같아요
intel329 6 Posted December 24, 2022 Posted December 24, 2022 13 hours ago, dgdfherthfh26 said: 3.2.77로 다운그레이드 하세요. 얘네 믿다간 위의 사례처럼 1년 이상 걸릴 것 같아요 감사합니다... 덕분에 수동으로 APK(3.2.77) 받아서 설치 했습니다. 해결아닌 해결을 했네요.. 언제 해결될지 몰라서 다운 그레이드 상태로 써야겠네요...
Luke 42243 Posted January 9, 2023 Posted January 9, 2023 HI, apologies for the delay. We are looking into this. 1
Seungwoo 2 Posted January 9, 2023 Posted January 9, 2023 4 hours ago, Luke said: HI, apologies for the delay. We are looking into this. hello. I am also Korean. I am also suffering from this problem. I hope you can solve this problem even if it is late. thank you. 1
rooser11 8 Posted January 24, 2023 Posted January 24, 2023 @Lukesince this issue was reported and you became aware of the problem, you released at least .90 and .92 and yet the problem still persists. I am actually very disappointed by the lack of quick patch and will consider other apps than emby.
Luke 42243 Posted August 1, 2023 Posted August 1, 2023 https://emby.media/community/index.php?/topic/113190-48013korean-display-exception/page/2/#comment-1269713
intel329 6 Posted August 3, 2023 Posted August 3, 2023 This problem is still ongoing. Synology emby Version 4.7.13.0 and Android emby 3.3.07 on Galaxy s9........
Luke 42243 Posted August 3, 2023 Posted August 3, 2023 6 hours ago, intel329 said: This problem is still ongoing. Synology emby Version 4.7.13.0 and Android emby 3.3.07 on Galaxy s9........
Seungwoo 2 Posted August 4, 2023 Posted August 4, 2023 (edited) After changing to the GoNotoKurrent-Regular font file on the server, ass subtitles work well in the web browser environment. However, in the Android app environment, the issue is not resolved. It seems to use the app's own font. I think you need to modify the font in the Android app as well. The iPad app worked fine without that issue. Edited August 4, 2023 by Seungwoo 1
intel329 6 Posted August 4, 2023 Posted August 4, 2023 It is normal to use the Galaxy Android system font. The font used in the previous version of emby for Android 3.2.77, works fine. Why is the previous font no longer available? It is very disappointing that this problem has taken so long..
cibalsebal 2 Posted October 29, 2023 Posted October 29, 2023 The emby team still hasn't fixed the Korean subtitle output I've been using the life cycle since the beginning of emby, but it's gotten to the point where I can't use emby anymore The emby android app is still unreadable, the emby android tv app doesn't show subtitles at all, chromecast has a slow connection and can't play in the middle position The point is, it's become the worst player ever I knew it was pointless to wait any longer. 1
Luke 42243 Posted October 30, 2023 Posted October 30, 2023 Apologies for the delay. This should be resolved in the next update to our apps and server. Thanks.
aperoid 0 Posted November 10, 2023 Author Posted November 10, 2023 (edited) Bazinga !!! Wooow it passed a Year~ (sarcasm (chuckles)) finally~ it is Sure Right?? its gonna b fixed on Next Update? im not going anywhere~ Edited November 10, 2023 by aperoid
