fredflix 31 Posted November 10, 2022 Posted November 10, 2022 (edited) Devices tested on: Shield 2017, Shield 2019 Emby Android TV client version: 2.0.83g Emby Server version: 4.7.9.0 I have a TV show here that has Dolby Digital Plus with Dolby Atmos audio as its audio track. Here's the mediainfo of the audio: Audio ID : 2 Format : E-AC-3 JOC Format/Info : Enhanced AC-3 with Joint Object Coding Commercial name : Dolby Digital Plus with Dolby Atmos Codec ID : A_EAC3 Duration : 46 min 18 s Bit rate mode : Constant Bit rate : 768 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 254 MiB (20%) Language : English Service kind : Complete Main Default : Yes Forced : No Complexity index : 16 Number of dynamic objects : 15 Bed channel count : 1 channel Bed channel configuration : LFE When trying to attempt to play any of the episodes, I get the "Too many errors, giving up" message. Looking at the server logs (attached below), it seems it's related to the audio. The files play fine in VLC on both Shields, and on Emby Theater on my PC as well. Tried looking here in the forums but didn't find anything related to DD+ Atmos audio. embyserver.txt ffmpeg-remux-40ec91c4-c38d-4669-a013-9973fac5c8ea_1.txt Edited November 10, 2022 by fredflix
ebr 16337 Posted November 10, 2022 Posted November 10, 2022 Can you please play that item until it fails and then follow the instructions to send a log from the app?
fredflix 31 Posted November 11, 2022 Author Posted November 11, 2022 17 hours ago, ebr said: Can you please play that item until it fails and then follow the instructions to send a log from the app? Log sent at 9:39 AM ET Tried to play episode 1 of season 1: Guillermo del Toros Cabinet of Curiosities Emby user: Big Red
ebr 16337 Posted November 11, 2022 Posted November 11, 2022 I'm seeing a couple of issues. One is that the player is just throwing a generic "source error" load exception trying to load the file. I'm wondering if maybe it is related to the fact that this item appears to have about 60 subtitle tracks. Do you have something without all of that in it to test with?
fredflix 31 Posted November 11, 2022 Author Posted November 11, 2022 39 minutes ago, ebr said: I'm seeing a couple of issues. One is that the player is just throwing a generic "source error" load exception trying to load the file. I'm wondering if maybe it is related to the fact that this item appears to have about 60 subtitle tracks. Do you have something without all of that in it to test with? Unfortunately I do not. This is the 1st time I've encountered a media that Emby can't play. This episode has 1 video track, 1 audio track and 34 subtitle tracks, way less than the 60 you're seeing. General Format : Matroska Format version : Version 4 File size : 1.26 GiB Duration : 46 min 18 s Overall bit rate : 3 894 kb/s Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L4@Main HDR format : Dolby Vision, Version 1.0, dvhe.08.03, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 44 min 57 s Bit rate : 3 214 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 24.000 FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.065 Stream size : 1.01 GiB (80%) Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 1368 cd/m2 Maximum Frame-Average Light Level : 126 cd/m2 Audio ID : 2 Format : E-AC-3 JOC Format/Info : Enhanced AC-3 with Joint Object Coding Commercial name : Dolby Digital Plus with Dolby Atmos Codec ID : A_EAC3 Duration : 46 min 18 s Bit rate mode : Constant Bit rate : 768 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 254 MiB (20%) Language : English Service kind : Complete Main Default : Yes Forced : No Complexity index : 16 Number of dynamic objects : 15 Bed channel count : 1 channel Bed channel configuration : LFE Text #1 ID : 3 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 26 min 26 s Bit rate : 0 b/s Frame rate : 0.005 FPS Count of elements : 8 Stream size : 159 Bytes (0%) Title : Forced Language : English Default : Yes Forced : Yes Text #2 ID : 4 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 45 s Bit rate : 65 b/s Frame rate : 0.254 FPS Count of elements : 682 Stream size : 21.3 KiB (0%) Title : SDH Language : English Default : No Forced : No Text #3 ID : 5 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 87 b/s Frame rate : 0.197 FPS Count of elements : 529 Stream size : 28.6 KiB (0%) Language : Arabic Default : No Forced : No Text #4 ID : 6 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 49 b/s Frame rate : 0.190 FPS Count of elements : 509 Stream size : 16.3 KiB (0%) Language : Czech Default : No Forced : No Text #5 ID : 7 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 53 b/s Frame rate : 0.178 FPS Count of elements : 477 Stream size : 17.5 KiB (0%) Language : Danish Default : No Forced : No Text #6 ID : 8 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 54 b/s Frame rate : 0.183 FPS Count of elements : 490 Stream size : 17.7 KiB (0%) Language : German Default : No Forced : No Text #7 ID : 9 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 43 min 44 s Bit rate : 90 b/s Frame rate : 0.197 FPS Count of elements : 517 Stream size : 28.9 KiB (0%) Language : Greek Default : No Forced : No Text #8 ID : 10 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 49 b/s Frame rate : 0.193 FPS Count of elements : 517 Stream size : 16.3 KiB (0%) Title : Latin American Language : Spanish Default : No Forced : No Text #9 ID : 11 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 53 b/s Frame rate : 0.211 FPS Count of elements : 566 Stream size : 17.4 KiB (0%) Title : European Language : Spanish Default : No Forced : No Text #10 ID : 12 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 49 b/s Frame rate : 0.184 FPS Count of elements : 494 Stream size : 16.4 KiB (0%) Language : Finnish Default : No Forced : No Text #11 ID : 13 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 53 b/s Frame rate : 0.187 FPS Count of elements : 503 Stream size : 17.4 KiB (0%) Language : fil Default : No Forced : No Text #12 ID : 14 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 53 b/s Frame rate : 0.189 FPS Count of elements : 506 Stream size : 17.7 KiB (0%) Language : French Default : No Forced : No Text #13 ID : 15 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 43 min 49 s Bit rate : 81 b/s Frame rate : 0.210 FPS Count of elements : 552 Stream size : 26.1 KiB (0%) Language : Hebrew Default : No Forced : No Text #14 ID : 16 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 46 b/s Frame rate : 0.188 FPS Count of elements : 504 Stream size : 15.1 KiB (0%) Language : Croatian Default : No Forced : No Text #15 ID : 17 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 52 b/s Frame rate : 0.181 FPS Count of elements : 485 Stream size : 17.2 KiB (0%) Language : Hungarian Default : No Forced : No Text #16 ID : 18 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 49 b/s Frame rate : 0.192 FPS Count of elements : 514 Stream size : 16.2 KiB (0%) Language : Indonesian Default : No Forced : No Text #17 ID : 19 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 43 min 33 s Bit rate : 51 b/s Frame rate : 0.188 FPS Count of elements : 490 Stream size : 16.6 KiB (0%) Language : Italian Default : No Forced : No Text #18 ID : 20 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 54 b/s Frame rate : 0.201 FPS Count of elements : 538 Stream size : 18.0 KiB (0%) Language : Japanese Default : No Forced : No Text #19 ID : 21 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 65 b/s Frame rate : 0.222 FPS Count of elements : 595 Stream size : 21.6 KiB (0%) Language : Korean Default : No Forced : No Text #20 ID : 22 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 48 b/s Frame rate : 0.188 FPS Count of elements : 505 Stream size : 15.9 KiB (0%) Language : Malay Default : No Forced : No Text #21 ID : 23 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 49 b/s Frame rate : 0.184 FPS Count of elements : 493 Stream size : 16.4 KiB (0%) Language : Norwegian Bokmal Default : No Forced : No Text #22 ID : 24 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 43 s Bit rate : 51 b/s Frame rate : 0.189 FPS Count of elements : 508 Stream size : 16.8 KiB (0%) Language : Dutch Default : No Forced : No Text #23 ID : 25 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 47 b/s Frame rate : 0.189 FPS Count of elements : 507 Stream size : 15.6 KiB (0%) Language : Polish Default : No Forced : No Text #24 ID : 26 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 43 min 48 s Bit rate : 53 b/s Frame rate : 0.190 FPS Count of elements : 500 Stream size : 17.2 KiB (0%) Title : Brazilian Language : Portuguese Default : No Forced : No Text #25 ID : 27 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 52 b/s Frame rate : 0.185 FPS Count of elements : 495 Stream size : 17.1 KiB (0%) Title : European Language : Portuguese Default : No Forced : No Text #26 ID : 28 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 58 b/s Frame rate : 0.181 FPS Count of elements : 486 Stream size : 19.0 KiB (0%) Language : Romanian Default : No Forced : No Text #27 ID : 29 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 84 b/s Frame rate : 0.190 FPS Count of elements : 510 Stream size : 27.6 KiB (0%) Language : Russian Default : No Forced : No Text #28 ID : 30 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 48 b/s Frame rate : 0.175 FPS Count of elements : 470 Stream size : 15.7 KiB (0%) Language : Swedish Default : No Forced : No Text #29 ID : 31 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 122 b/s Frame rate : 0.194 FPS Count of elements : 521 Stream size : 40.3 KiB (0%) Language : Thai Default : No Forced : No Text #30 ID : 32 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 54 b/s Frame rate : 0.192 FPS Count of elements : 514 Stream size : 17.7 KiB (0%) Language : Turkish Default : No Forced : No Text #31 ID : 33 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 43 min 47 s Bit rate : 82 b/s Frame rate : 0.197 FPS Count of elements : 517 Stream size : 26.4 KiB (0%) Language : Ukrainian Default : No Forced : No Text #32 ID : 34 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 45 s Bit rate : 74 b/s Frame rate : 0.184 FPS Count of elements : 494 Stream size : 24.3 KiB (0%) Language : Vietnamese Default : No Forced : No Text #33 ID : 35 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 55 b/s Frame rate : 0.191 FPS Count of elements : 513 Stream size : 18.0 KiB (0%) Title : Simplified Language : Chinese Default : No Forced : No Text #34 ID : 36 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 44 min 42 s Bit rate : 53 b/s Frame rate : 0.216 FPS Count of elements : 580 Stream size : 17.4 KiB (0%) Title : Traditional Language : Chinese Default : No Forced : No Menu 00:00:00.000 : en:Part 01 00:43:56.450 : en:Credits
ebr 16337 Posted November 11, 2022 Posted November 11, 2022 Looks like they are doubled in the player. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
fredflix 31 Posted November 11, 2022 Author Posted November 11, 2022 1 minute ago, ebr said: Looks like they are doubled in the player. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks. You want me to load the phone version on the shield, that's what you're saying?
ebr 16337 Posted November 11, 2022 Posted November 11, 2022 Just now, fredflix said: You want me to load the phone version on the shield, that's what you're saying? Yes. It will recognize your Shield as a TV device and give you an appropriate interface. Thanks.
fredflix 31 Posted November 11, 2022 Author Posted November 11, 2022 10 minutes ago, ebr said: Yes. It will recognize your Shield as a TV device and give you an appropriate interface. Thanks. "Playback Error No compatible streams are currently available. Please try again later or contact your system administrator for details." This is trying with no subtitles selected if that helps.
fredflix 31 Posted November 11, 2022 Author Posted November 11, 2022 (edited) I just tried another show that has the exact same audio, and it plays fine. The only difference though is that that show is 4K, but is hybrid as well (has HDR and DV on the video) and has even more sub tracks (42). Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5@High HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 34 min 58 s Bit rate : 24.7 Mb/s Width : 3 840 pixels Height : 1 920 pixels Display aspect ratio : 2.000 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.140 Stream size : 6.04 GiB (97%) Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 170 cd/m2 Maximum Frame-Average Light Level : 101 cd/m2 Audio ID : 2 Format : E-AC-3 JOC Format/Info : Enhanced AC-3 with Joint Object Coding Commercial name : Dolby Digital Plus with Dolby Atmos Codec ID : A_EAC3 Duration : 34 min 58 s Bit rate mode : Constant Bit rate : 768 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 192 MiB (3%) Language : English Service kind : Complete Main Default : Yes Forced : No Complexity index : 16 Number of dynamic objects : 15 Bed channel count : 1 channel Bed channel configuration : LFE The problematic media is 1080p hybrid (HDR and DV on the video). Edited November 11, 2022 by fredflix
ebr 16337 Posted November 11, 2022 Posted November 11, 2022 1 hour ago, fredflix said: "Playback Error No compatible streams are currently available. Please try again later or contact your system administrator for details." This is trying with no subtitles selected if that helps. Okay, so same thing happening there. 1 hour ago, fredflix said: I just tried another show that has the exact same audio, and it plays fine Yeah, I think the audio is not related. Are these items on the same physical storage device?
fredflix 31 Posted November 11, 2022 Author Posted November 11, 2022 1 minute ago, ebr said: Okay, so same thing happening there. Yeah, I think the audio is not related. Are these items on the same physical storage device? Affirmative. I've also tried another show that has the same video: 1080p hybrid (DV and HDR combined), but with regular DDP+ no atmos and the shield plays it fine. I'm in the process of getting another episode from another show with the exact same video/audio combo and see if the problem also persists. But again, the problematic video plays fine with VLC on the shield and in Emby theater.
fredflix 31 Posted November 11, 2022 Author Posted November 11, 2022 (edited) Little update. Tried on another show that has the same audio and video and, as expected, can't play it either. I have to say that the 1080p H.265 DV/HDR10 with DDplus Atmos audio is a very rare combo. I could only find 2 shows in that format. I have also tested the following, all of them working fine: 1080p H.264 with DDplus Atmos 1080p H.265 HDR10 with DDplus Atmos 1080p H.265 DV/HDR10 with DDplus (no atmos) 2160p H.265 DV/HDR10 with DDplus Atmos EDIT: Forgot to mention that on top of VLC being able to play everything fine on the Shield, so does MPV. Edited November 11, 2022 by fredflix
fredflix 31 Posted December 8, 2022 Author Posted December 8, 2022 Been roughly a month and I still can't figure why some files won't play. All I can say for certain is: - It only affects the Android clients (mobile and TV). The files play fine on Emby's Desktop and iOS client. - It is not sound related contrary to what I initially thought (the log seems to suggest it's audio related, but it's not). - Problematic media files are MKV with HDR10 base layer, with an additional DV Profile 8 layer and a format profile of "Main 10@L5@Main" or "Main 10@L4@Main". Same kind of files with format profile of "Main 10@L5.1@Main", "Main 10@L5.1@High" and "Main 10@L5@High" seem to work fine however. - 1080p is as much affected as 2160p. So resolution doesn't seem to matter. - The files play fine with Jellyfin and Plex on Android TV (haven't tried their Android mobile client).
fredflix 31 Posted January 23, 2023 Author Posted January 23, 2023 I'm happy to report that after the latest Android app update, this is no longer an issue on the Nvidia Shield. If you could implement the changes to the Android TV app, that would be great as the issue still remains. Thanks!
Solution seanbuff 1356 Posted January 23, 2023 Solution Posted January 23, 2023 2 minutes ago, fredflix said: If you could implement the changes to the Android TV app, that would be great as the issue still remains. the same Exo updates have also been applied to the Android TV beta app Quote 2.087 (22 Jan) Fix crashes with items with no runtime Update Exoplayer 1
fredflix 31 Posted January 23, 2023 Author Posted January 23, 2023 Didn't notice the new update for the Android TV app, thanks a lot! 1
