Cefn Canol 3 Posted November 10, 2022 Posted November 10, 2022 Hi is it possible to have the same Movie/tv series in 2 diff folders, IE local folder /home/user/media/tv and /home/user/media/movies Local gdrive mount /home/user/gdrive/media/tv and /home/user/gdrive/media/tv Ive enabled TV "Automatically merge series that are spread across multiple folders" but still get 2 of everything same with Movies 2 of everything Strange thing is on my local server running windows I have *** TAKE NO NOTICE OF THE NAMING PLEX FOLDER *** F:\PLEX_VIDEO\TV Shows H:\storage\Media\TV Shows And that works ok?
Happy2Play 9800 Posted November 10, 2022 Posted November 10, 2022 Tv should work with the setting. May need to look at specific example if it is not working. But Movie will not as there is only a option in the server core for media in same folder with specific naming scheme. You have to manually group or use the plug if they are in separate folders.
Cefn Canol 3 Posted November 10, 2022 Author Posted November 10, 2022 Thanks for your quick reply, Found that tv folder is still "scanning" so might be ok when finished, as for the movie ill make a seprate folder Thanks again 1
