rastriffler 0 Posted November 10, 2022 Posted November 10, 2022 (edited) Hey folks, I am having some intermittant issues with playback freezing, - only when playing a movie from a remote location (most recently, in Safari on a macBook Air), and possibly due to others logged in and streaming movies. Sometimes it will resume, other times I have to back out of the movie and restart it. Server has been up and running for years and kept up to date with releases, but there could still be something fairly basic in my setup that I am missing. Any feedback is very welcome! Here is my setup: macOS Catalina, Version 10.15.7 running on a Mac mini (Late 2012) - this is a dedicated Emby server, so nothing should be competing for resources Processor 2.5 GHz Dual -Core Intel Core 15 Memory 16 GB 1600 MHz DDR3 500GB internal hard drive (non-SSD, formatted APFS) Entire Emby library (~375GB) stored on a 4TB external USB drive formatted MacOS Extended (Journaled) Our home network regularly gets 200+ mbps, and there are rarely more than 3 people watching different movies simultaneously All movies are .mp4 format, and range between 1GB and 4.5GB in size. All have been converted using Handbrake. I didn't think that any of the movies would require transcoding (and have recently turned that off), but am including the ffmpeg-transcode log that was generated since it seems that may be happening with a few movies and I need to understand why. I believe it's only happening for a recent movie I may not have converted/reduced properly. Thanks very much! embyserver-63803458786.txt ffmpeg-transcode-f7bd472b-2946-4506-a75f-024699e20ef7_1.txt Edited November 10, 2022 by rastriffler
Luke 42237 Posted November 10, 2022 Posted November 10, 2022 Hi, please try lowering the in app quality setting a bit further and see if that helps. That usually will help with this kind of problem. Thanks.
rastriffler 0 Posted November 10, 2022 Author Posted November 10, 2022 41 minutes ago, Luke said: Hi, please try lowering the in app quality setting a bit further and see if that helps. That usually will help with this kind of problem. Thanks. I've tried that when using iPhone, or TV app to playback, but didn't think that was an option when watching from the browser.
Luke 42237 Posted December 15, 2022 Posted December 15, 2022 On 11/10/2022 at 1:10 PM, rastriffler said: I've tried that when using iPhone, or TV app to playback, but didn't think that was an option when watching from the browser. Hi, yes it's always an option. There is a gear button in the video player, and you can also configure the quality setting in the app's playback settings. The web app has this as well. Please let us know if this helps. Thanks !
rastriffler 0 Posted January 5, 2025 Author Posted January 5, 2025 Bumping this old thread with a related question... On mac, does the formatting of the system hard drive need to match the formating of the external drive being used to house the library files? E.g., my system drive is formatted APFS and the external drive is formatted MacOS Extended (Journaled). Would performance improve if the were the same? Also wondering if the fact that the library files are on an external USB drive is hindering performance. Thanks!
Luke 42237 Posted January 6, 2025 Posted January 6, 2025 Quote E.g., my system drive is formatted APFS and the external drive is formatted MacOS Extended (Journaled). Would performance improve if the were the same? Hi, I don't think being the same matters. What matters more would be the performance characteristics of the two file systems. And how well the dotnet runtime handles them (or doesn't). External USB will typically be slower, but you can mitigate that to a degree by enabling the library option to keep a cached copy of images. This will reduce the frequency of having to access the disk directly after the library has been imported into the server. 1
