soboku 2 Posted November 11, 2022 Author Posted November 11, 2022 Ok all do that. Now all I did was sent you the logs. If I was to activate a capture function first I didn't do that. Not sure how to do a capture.
Junglejim 385 Posted November 12, 2022 Posted November 12, 2022 (edited) On 10/11/2022 at 10:50, soboku said: sorry sifi missed spelled it is /movie/SyFi/Alien3.m4v @Happy2Play The sub folder shouldn't matter that much (SyFi) but the naming of the actual file does. It takes some work on your part but for this example.. "Alien3.m4v" would work better if it was "Alien³ (1992).m4v". Personally I put all my movies in there own sub folders (/movie/SyFi/Alien³ (1992)/Alien³ (1992).m4v) but that could take some unwanted work. Just try to name your files the same as the scraper involved in grabbing the metadata, eg.. https://www.themoviedb.org/movie/8077-alien Just copy&paste the title. Edited November 12, 2022 by Junglejim
Luke 42239 Posted November 13, 2022 Posted November 13, 2022 Having said that, when I search moviedb for alien3 it does return the right result, so in theory it should have been fine. But I still would recommend better with the year in the file name. @sobokuhas this helped?
soboku 2 Posted November 13, 2022 Author Posted November 13, 2022 all right I am going to start the renaming of all my library with that in mind. This will take over a month to do so for now I guess all let you guys go. Thank you all for all the input I am so thankful. All re post next month with the results.
soboku 2 Posted December 9, 2022 Author Posted December 9, 2022 I made the changes, adding the date to the name and so for every thing on the ones I made the change to has stayed. So to do my whole library will take a lot of time. I think by putting the date in was the answer so for now lets consider the problem solved. Because it will take me months to go through my entire library and update the titles. Thank you all for all of your suggestions and help you've been awesome. Sorry it took a bit of time to get back with you its been very busy here. I'v been in a bit of rush to get some beta testing done in time to deal with eeeggg "holidays" lol. 1
