exus 17 Posted November 8, 2022 Posted November 8, 2022 I'm running windows 11 (5950x and a 3080ti) and emby theater UI is running super slow compared to the browser version (even the playback is not smooth) I recorder a small video with a side by side comparison between browser and emby app 2022-11-08 10-11-29_edit.mkv
exus 17 Posted November 9, 2022 Author Posted November 9, 2022 (edited) I've found a workaround, this issue is caused by the "background application max frame rate" global setting in Nvidia control panel. mine was set to 20 FPS and it looks like the emby window is always considered in background. I excluded this setting from Electron.exe and it's now running smoothly Edited November 9, 2022 by exus
Luke 42237 Posted November 9, 2022 Posted November 9, 2022 Hi that's interesting, thanks for following up.
Brecon 6 Posted August 27, 2023 Posted August 27, 2023 (edited) Ive just bought the Minix J51-C8 Max mini PC using windows 11 pro. My problem is when I install windows store version of Emby theatre it runs smoothly but the UI is old. So I installed emby’s own version from their website as the UI is much newer and better…. But the problem is when I play anything in 4K which is most of my movies the film is like in slow motion. Is this fixable .. any help appreciated. My widows 11 Pro is completely up to date Edited August 27, 2023 by Brecon
Luke 42237 Posted August 27, 2023 Posted August 27, 2023 3 hours ago, Brecon said: Ive just bought the Minix J51-C8 Max mini PC using windows 11 pro. My problem is when I install windows store version of Emby theatre it runs smoothly but the UI is old. So I installed emby’s own version from their website as the UI is much newer and better…. But the problem is when I play anything in 4K which is most of my movies the film is like in slow motion. Is this fixable .. any help appreciated. My widows 11 Pro is completely up to date Why do you think the ui is old? They are the same .
Brecon 6 Posted August 27, 2023 Posted August 27, 2023 You can’t resize the folder etc, your own version you can edit the size of each folder, you can’t on the windows version. Thank you for coming back to me. And also if they are the same why is it the window version works fine in relation to playing 4k movies but your version has a problem. Sorry not not picking was wondering why. Thanks again
Luke 42237 Posted August 28, 2023 Posted August 28, 2023 10 hours ago, Brecon said: You can’t resize the folder etc, your own version you can edit the size of each folder, you can’t on the windows version. Thank you for coming back to me. And also if they are the same why is it the window version works fine in relation to playing 4k movies but your version has a problem. Sorry not not picking was wondering why. Thanks again What do you mean by can't resize the folder? Maybe you just need to set the app display mode setting to TV? That should be the only visual difference out of the box.
