Problem with images sizes web and android apk
CAPRICORNX10X
On the web, there is a certain problem when choosing an image size
If you set an image as the default size
And if you set an image as a small size
They are the same size!!!
In addition
In android apk when choosing image size there is the same problem
And if you set an image as normal size
Please pay attention to this and give it consideration.
Maybe cancel the default size, or something else. But this is a problem that needs to be fixed.
Hi there, please provide a specific example. Thanks.
CAPRICORNX10X
small and default have the same display sizes !
arrbee99
There's Normal AND Default ?
Yes because you can set an application default in view settings. Or should we take that away in order to make the choices easier to understand?
This might be normal sometimes if Default is the same as small. Nothing is wrong.
CAPRICORNX10X
Don't know...complicates things a bit.
There should be a clear order of sizes, each of which is different from the other. That's my opinion
There is, but if you set the application default to Small, then that means Default and Small will be the same.
CAPRICORNX10X
That is not accurate.
Because the default set in the settings affects the home screen.
And not for example on my media.
So the default is not relevant for displaying content inside my media
arrbee99
i"m still confused, which isn't unusual. Don't think I'd get rid of anything, but some form of clarification for that image size option would, I imagine, help.
If it matters I use small on the Android app, but leave as is for my browser. I don't know what affects what, especially with my css. For me the only thing in my browser affected by the settings on Android is making episode pictures smaller, which is ironic considering how huge they are on the Android app.
CAPRICORNX10X
I did not say that there is an effect on the choice of image size between Android and web.
I just stated what the problem is on each platform.
arrbee99
True, but I do have a bad habit of mentioning similar-ish things on other peoples threads. One of my many failings, ask my other half...
CAPRICORNX10X
Oh ok 😄
