bo83_emby 3 Posted April 14, 2023 Posted April 14, 2023 12 hours ago, cayars said: @bo83_embyDid you use the "DSM 6 to DSM 7 Emby Migration Instructions" guide mentioned above? Yes i did. 1
adam.niescierowicz 6 Posted July 24, 2023 Posted July 24, 2023 Hi, there is also error with AniDB provider. Server time and date are fine. Using wget I can download image Logs Quote 2023-07-24 14:53:39.420 Info HttpClient: GET http://img7.anidb.net/pics/anime/17039.jpg 2023-07-24 14:53:39.602 Error HttpClient: Error getting response from http://img7.anidb.net/pics/anime/17039.jpg *** Error Report *** Version: 4.7.13.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby-server -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 4.15.0-1-amd64 (debian-kernel@lists.debian.org) (gcc version 7.3.0 (Debian 7.3.0-3)) #1 SMP Debian 4.15.4-1 (2018-02-18) Framework: .NET 6.0.14 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 20 Data path: /var/lib/emby-server Application path: /opt/emby-server/system System.Net.Http.HttpRequestException: System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception. ---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid because of errors in the certificate chain: NotTimeValid at System.Net.Security.SslStream.SendAuthResetSignal(ProtocolToken message, ExceptionDispatchInfo exception) at System.Net.Security.SslStream.CompleteHandshake(SslAuthenticationOptions sslAuthenticationOptions) at System.Net.Security.SslStream.ForceAuthenticationAsync[TIOAdapter](TIOAdapter adapter, Boolean receiveFirst, Byte[] reAuthenticationData, Boolean isApm) at System.Net.Http.ConnectHelper.EstablishSslConnectionAsync(SslClientAuthenticationOptions sslOptions, HttpRequestMessage request, Boolean async, Stream stream, CancellationToken cancellationToken) --- End of inner exception stack trace --- at System.Net.Http.ConnectHelper.EstablishSslConnectionAsync(SslClientAuthenticationOptions sslOptions, HttpRequestMessage request, Boolean async, Stream stream, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.AddHttp11ConnectionAsync(HttpRequestMessage request) at System.Threading.Tasks.TaskCompletionSourceWithCancellation`1.WaitWithCancellationAsync(CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.GetHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.DecompressionHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) Source: System.Net.Http TargetSite: Void MoveNext() InnerException: System.Security.Authentication.AuthenticationException: The remote certificate is invalid because of errors in the certificate chain: NotTimeValid Source: System.Private.CoreLib TargetSite: Void Throw() at System.Net.Security.SslStream.SendAuthResetSignal(ProtocolToken message, ExceptionDispatchInfo exception) at System.Net.Security.SslStream.CompleteHandshake(SslAuthenticationOptions sslAuthenticationOptions) at System.Net.Security.SslStream.ForceAuthenticationAsync[TIOAdapter](TIOAdapter adapter, Boolean receiveFirst, Byte[] reAuthenticationData, Boolean isApm) at System.Net.Http.ConnectHelper.EstablishSslConnectionAsync(SslClientAuthenticationOptions sslOptions, HttpRequestMessage request, Boolean async, Stream stream, CancellationToken cancellationToken)
Luke 42245 Posted July 24, 2023 Posted July 24, 2023 7 hours ago, adam.niescierowicz said: Hi, there is also error with AniDB provider. Server time and date are fine. Using wget I can download image Logs Strange, but usually it that error is time related. I would give it a day and see if it is still am issue.
adam.niescierowicz 6 Posted July 25, 2023 Posted July 25, 2023 (edited) Next day problem still there, this time logs from tmdb @Lukeis there a chance to create some kind debug script that we can check what is causing this problem? If you can catch error NotTimeValid, can you dump cert details in the logs with date etc.? Quote 2023-07-25 09:24:41.461 Error HttpClient: Error getting response from https://image.tmdb.org/t/p/original/fyInDgBLeqc9XfB0BN0SIBFKlzh.jpg *** Error Report *** Version: 4.7.13.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby-server -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 4.15.0-1-amd64 (debian-kernel@lists.debian.org) (gcc version 7.3.0 (Debian 7.3.0-3)) #1 SMP Debian 4.15.4-1 (2018-02-18) Framework: .NET 6.0.14 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 20 Data path: /var/lib/emby-server Application path: /opt/emby-server/system System.Net.Http.HttpRequestException: System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception. ---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid because of errors in the certificate chain: NotTimeValid at System.Net.Security.SslStream.SendAuthResetSignal(ProtocolToken message, ExceptionDispatchInfo exception) at System.Net.Security.SslStream.CompleteHandshake(SslAuthenticationOptions sslAuthenticationOptions) at System.Net.Security.SslStream.ForceAuthenticationAsync[TIOAdapter](TIOAdapter adapter, Boolean receiveFirst, Byte[] reAuthenticationData, Boolean isApm) at System.Net.Http.ConnectHelper.EstablishSslConnectionAsync(SslClientAuthenticationOptions sslOptions, HttpRequestMessage request, Boolean async, Stream stream, CancellationToken cancellationToken) --- End of inner exception stack trace --- at System.Net.Http.ConnectHelper.EstablishSslConnectionAsync(SslClientAuthenticationOptions sslOptions, HttpRequestMessage request, Boolean async, Stream stream, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.AddHttp11ConnectionAsync(HttpRequestMessage request) at System.Threading.Tasks.TaskCompletionSourceWithCancellation`1.WaitWithCancellationAsync(CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.GetHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.DecompressionHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) Source: System.Net.Http TargetSite: Void MoveNext() InnerException: System.Security.Authentication.AuthenticationException: The remote certificate is invalid because of errors in the certificate chain: NotTimeValid Source: System.Private.CoreLib TargetSite: Void Throw() at System.Net.Security.SslStream.SendAuthResetSignal(ProtocolToken message, ExceptionDispatchInfo exception) at System.Net.Security.SslStream.CompleteHandshake(SslAuthenticationOptions sslAuthenticationOptions) at System.Net.Security.SslStream.ForceAuthenticationAsync[TIOAdapter](TIOAdapter adapter, Boolean receiveFirst, Byte[] reAuthenticationData, Boolean isApm) at System.Net.Http.ConnectHelper.EstablishSslConnectionAsync(SslClientAuthenticationOptions sslOptions, HttpRequestMessage request, Boolean async, Stream stream, CancellationToken cancellationToken) Edited July 25, 2023 by adam.niescierowicz
ChaoOos 2 Posted July 26, 2023 Posted July 26, 2023 Hi, i have the same Problem with Synology 7.2 (i know its linux too ) 2023-07-26 11:37:27.329 Error HttpClient: Error getting response from https://image.tmdb.org/t/p/original/8BNky5updEmoOPerYU9h5RgqM4H.jpg *** Error Report *** Version: 4.7.13.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology72_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.302+ (root@build7) (gcc version 12.2.0 (GCC) ) #64570 SMP Tue Jun 13 21:40:17 CST 2023 Framework: .NET 6.0.14 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.Net.Http.HttpRequestException: System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception. ---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid because of errors in the certificate chain: NotTimeValid at System.Net.Security.SslStream.SendAuthResetSignal(ProtocolToken message, ExceptionDispatchInfo exception) at System.Net.Security.SslStream.CompleteHandshake(SslAuthenticationOptions sslAuthenticationOptions) at System.Net.Security.SslStream.ForceAuthenticationAsync[TIOAdapter](TIOAdapter adapter, Boolean receiveFirst, Byte[] reAuthenticationData, Boolean isApm) at System.Net.Http.ConnectHelper.EstablishSslConnectionAsync(SslClientAuthenticationOptions sslOptions, HttpRequestMessage request, Boolean async, Stream stream, CancellationToken cancellationToken) --- End of inner exception stack trace --- at System.Net.Http.ConnectHelper.EstablishSslConnectionAsync(SslClientAuthenticationOptions sslOptions, HttpRequestMessage request, Boolean async, Stream stream, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.AddHttp11ConnectionAsync(HttpRequestMessage request) at System.Threading.Tasks.TaskCompletionSourceWithCancellation`1.WaitWithCancellationAsync(CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.GetHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.DecompressionHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) Source: System.Net.Http TargetSite: Void MoveNext() InnerException: System.Security.Authentication.AuthenticationException: The remote certificate is invalid because of errors in the certificate chain: NotTimeValid Source: System.Private.CoreLib TargetSite: Void Throw() at System.Net.Security.SslStream.SendAuthResetSignal(ProtocolToken message, ExceptionDispatchInfo exception) at System.Net.Security.SslStream.CompleteHandshake(SslAuthenticationOptions sslAuthenticationOptions) at System.Net.Security.SslStream.ForceAuthenticationAsync[TIOAdapter](TIOAdapter adapter, Boolean receiveFirst, Byte[] reAuthenticationData, Boolean isApm) at System.Net.Http.ConnectHelper.EstablishSslConnectionAsync(SslClientAuthenticationOptions sslOptions, HttpRequestMessage request, Boolean async, Stream stream, CancellationToken cancellationToken) 2023-07-26 11:37:27.334 Error Server: Error processing request *** Error Report *** Version: 4.7.13.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology72_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.302+ (root@build7) (gcc version 12.2.0 (GCC) ) #64570 SMP Tue Jun 13 21:40:17 CST 2023 Framework: .NET 6.0.14 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.Net.Http.HttpRequestException: System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception. ---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid because of errors in the certificate chain: NotTimeValid at System.Net.Security.SslStream.SendAuthResetSignal(ProtocolToken message, ExceptionDispatchInfo exception) at System.Net.Security.SslStream.CompleteHandshake(SslAuthenticationOptions sslAuthenticationOptions) at System.Net.Security.SslStream.ForceAuthenticationAsync[TIOAdapter](TIOAdapter adapter, Boolean receiveFirst, Byte[] reAuthenticationData, Boolean isApm) at System.Net.Http.ConnectHelper.EstablishSslConnectionAsync(SslClientAuthenticationOptions sslOptions, HttpRequestMessage request, Boolean async, Stream stream, CancellationToken cancellationToken) --- End of inner exception stack trace --- at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Providers.Manager.ProviderManager.SaveImageFromRemoteUrl(BaseItem item, LibraryOptions libraryOptions, String url, ImageType type, Nullable`1 imageIndex, Boolean isFallbackImage, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.LibraryManager.ConvertImageToLocal(BaseItem item, ItemImageInfo image, Int32 imageIndex, CancellationToken cancellationToken) at Emby.Drawing.ImageProcessor.ProcessImage(ImageProcessingOptions options, CancellationToken cancellationToken) at Emby.Api.Images.ImageService.GetImage(ImageRequest request, Int64 itemId, BaseItem item, Boolean isHeadRequest) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost httpHost, IServerApplicationHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: System.Net.Http TargetSite: Void MoveNext() InnerException: System.Security.Authentication.AuthenticationException: The remote certificate is invalid because of errors in the certificate chain: NotTimeValid Source: System.Private.CoreLib TargetSite: Void Throw() at System.Net.Security.SslStream.SendAuthResetSignal(ProtocolToken message, ExceptionDispatchInfo exception) at System.Net.Security.SslStream.CompleteHandshake(SslAuthenticationOptions sslAuthenticationOptions) at System.Net.Security.SslStream.ForceAuthenticationAsync[TIOAdapter](TIOAdapter adapter, Boolean receiveFirst, Byte[] reAuthenticationData, Boolean isApm) at System.Net.Http.ConnectHelper.EstablishSslConnectionAsync(SslClientAuthenticationOptions sslOptions, HttpRequestMessage request, Boolean async, Stream stream, CancellationToken cancellationToken) my Certificate is new and ok. (i hope). i created my .p12 cert in the beginning of july. AniDB errors i have too
Luke 42245 Posted July 27, 2023 Posted July 27, 2023 On 7/25/2023 at 4:58 AM, adam.niescierowicz said: Next day problem still there, this time logs from tmdb @Lukeis there a chance to create some kind debug script that we can check what is causing this problem? If you can catch error NotTimeValid, can you dump cert details in the logs with date etc.? Is this impacting all Moviedb requests?
adam.niescierowicz 6 Posted July 28, 2023 Posted July 28, 2023 Quote Is this impacting all Moviedb requests? For 23 to tmdb 12 has errors(today stats), logs below Quote 2023-07-28 09:05:24.273 Info HttpClient: GET https://image.tmdb.org/t/p/original/j9eoGICQKRJq5FSq3i1ZV55kf1H.jpg 2023-07-28 09:05:24.366 Error HttpClient: Error getting response from https://image.tmdb.org/t/p/original/j9eoGICQKRJq5FSq3i1ZV55kf1H.jpg 2023-07-28 10:44:00.291 Info HttpClient: GET https://image.tmdb.org/t/p/original/ompc0zqqG9ZV34ymLO4UwBOH0Q7.jpg 2023-07-28 10:44:00.291 Info HttpClient: GET https://image.tmdb.org/t/p/original/siFE5F4ReT1krbu3kPseVx0OO6T.jpg 2023-07-28 10:44:00.384 Error HttpClient: Error getting response from https://image.tmdb.org/t/p/original/siFE5F4ReT1krbu3kPseVx0OO6T.jpg 2023-07-28 10:44:29.405 Info HttpClient: GET https://image.tmdb.org/t/p/original/hQDz5QYioH6FbcftHi1C7smUyhV.jpg 2023-07-28 10:44:47.165 Info HttpClient: GET https://image.tmdb.org/t/p/original/3hmcqU1OfLZ5kbvl7url63VuWMJ.jpg 2023-07-28 11:22:19.552 Info HttpClient: GET https://image.tmdb.org/t/p/original/dqSkdg0buh8zpf9UfOoovsDjJwX.jpg 2023-07-28 11:22:19.620 Error HttpClient: Error getting response from https://image.tmdb.org/t/p/original/dqSkdg0buh8zpf9UfOoovsDjJwX.jpg 2023-07-28 11:22:23.041 Info HttpClient: GET https://image.tmdb.org/t/p/original/AtzhmC87QIgrIVoblaj6TVNbM6I.jpg 2023-07-28 11:23:59.997 Info HttpClient: GET https://image.tmdb.org/t/p/original/13tqYbaMCSLco7ST0MoME9docwK.jpg 2023-07-28 11:24:00.063 Error HttpClient: Error getting response from https://image.tmdb.org/t/p/original/13tqYbaMCSLco7ST0MoME9docwK.jpg 2023-07-28 11:26:28.763 Info HttpClient: GET https://image.tmdb.org/t/p/original/7iEugfZ8imAI6GSWIfZvhg1ZZoc.jpg 2023-07-28 11:26:28.833 Error HttpClient: Error getting response from https://image.tmdb.org/t/p/original/7iEugfZ8imAI6GSWIfZvhg1ZZoc.jpg 2023-07-28 11:28:35.622 Info HttpClient: GET https://image.tmdb.org/t/p/original/d030uTB6ATYw9GHduuuE1E8eO4g.jpg 2023-07-28 11:30:52.401 Info HttpClient: GET https://image.tmdb.org/t/p/original/tHkCm58B5021QXuoelMXuFzg238.jpg 2023-07-28 11:30:52.480 Error HttpClient: Error getting response from https://image.tmdb.org/t/p/original/tHkCm58B5021QXuoelMXuFzg238.jpg 2023-07-28 11:32:56.258 Info HttpClient: GET https://image.tmdb.org/t/p/original/ucALpX43MFp2nkvWGihEwHWhwIp.jpg 2023-07-28 11:34:36.890 Info HttpClient: GET https://image.tmdb.org/t/p/original/tH7a08Mj39gXpRstGl1qs6vJpHU.jpg 2023-07-28 11:36:39.125 Info HttpClient: GET https://image.tmdb.org/t/p/original/pqdmeQZ0Xa4dPUhUznlrzQuveoT.jpg 2023-07-28 11:36:39.191 Error HttpClient: Error getting response from https://image.tmdb.org/t/p/original/pqdmeQZ0Xa4dPUhUznlrzQuveoT.jpg 2023-07-28 11:38:09.516 Info HttpClient: GET https://image.tmdb.org/t/p/original/plzxedJrWfbH1XGqcx2z7l6QOhw.jpg 2023-07-28 11:39:55.076 Info HttpClient: GET https://image.tmdb.org/t/p/original/zHBe20HMFFKlSd9vm1EbYzvwOHO.jpg 2023-07-28 11:39:55.158 Error HttpClient: Error getting response from https://image.tmdb.org/t/p/original/zHBe20HMFFKlSd9vm1EbYzvwOHO.jpg 2023-07-28 11:41:19.670 Info HttpClient: GET https://image.tmdb.org/t/p/original/iYoMZYVD775MtBYJfv6OGY1FsnL.jpg 2023-07-28 11:41:19.738 Error HttpClient: Error getting response from https://image.tmdb.org/t/p/original/iYoMZYVD775MtBYJfv6OGY1FsnL.jpg 2023-07-28 12:05:32.053 Info HttpClient: GET https://image.tmdb.org/t/p/original/cP9CJ9nvPT3cnnBSlGFgwq7odIR.jpg 2023-07-28 12:05:32.130 Error HttpClient: Error getting response from https://image.tmdb.org/t/p/original/cP9CJ9nvPT3cnnBSlGFgwq7odIR.jpg 2023-07-28 12:21:37.801 Info HttpClient: GET https://image.tmdb.org/t/p/original/kJxqdEfInoai6Ca2tUEWbelveUP.jpg 2023-07-28 12:21:37.863 Error HttpClient: Error getting response from https://image.tmdb.org/t/p/original/kJxqdEfInoai6Ca2tUEWbelveUP.jpg 2023-07-28 12:36:09.514 Info HttpClient: GET https://image.tmdb.org/t/p/original/35EG2nZhvVF7Cf317wWpIJfQwWl.jpg 2023-07-28 13:28:50.965 Info HttpClient: GET https://image.tmdb.org/t/p/original/cZLbagRQKtyvl8o4SE0JhA1nNYZ.png 2023-07-28 13:28:51.053 Error HttpClient: Error getting response from https://image.tmdb.org/t/p/original/cZLbagRQKtyvl8o4SE0JhA1nNYZ.png 2023-07-28 14:23:20.401 Info HttpClient: GET https://image.tmdb.org/t/p/original/9lNSJ7l6Dc7aXVrywBlFxhNqXeF.jpg
Q-Droid 1011 Posted July 28, 2023 Posted July 28, 2023 Have you tried changing your DNS resolver on the Emby server? Just as a test.
Q-Droid 1011 Posted July 28, 2023 Posted July 28, 2023 Another thing to check - this one is an oldie... Do you have any files under ~emby/.dotnet/corefx/cryptography/x509stores/ca?
adam.niescierowicz 6 Posted July 28, 2023 Posted July 28, 2023 (edited) Quote Have you tried changing your DNS resolver on the Emby server? Just as a test. Correct me if I'm wrong but if the problem is with DNS so the wget also shouldn't work, yes? Quote Do you have any files under ~emby/.dotnet/corefx/cryptography/x509stores/ca? Yes, 3 Quote 33E4E80807204C2B6182A3A14B591ACD25B5F0DB.pfx 48504E974C0DAC5B5CD476C8202274B24C8C7172.pfx E6A3B45B062D509B3382282D196EFE97D5956CCB.pfx Edited July 28, 2023 by adam.niescierowicz
Q-Droid 1011 Posted July 28, 2023 Posted July 28, 2023 44 minutes ago, adam.niescierowicz said: Correct me if I'm wrong but if the problem is with DNS so the wget also shouldn't work, yes? Yes, 3 I don't think the problem is with DNS and my suggestion was more of an exercise of elimination. But let's start with the last thing. Do you have dates on those files? Not important but I'm curious. Regarding those files, what you can do with them is: 1. Stop the emby server. 2. Move those files to another directory, doesn't matter where as long as they're gone from this one. 3. Start the emby server. I suggest you move them just so that we can see their contents after. Then let Emby run and fetch images for a while to see if the errors come back. TL;DR for below - Different DNS service could respond with different endpoints for the cloud/CDN holding the images. Back to DNS. Connections from wget might not be using the same truststore as Emby. In fact I think they don't. The major public DNS providers (maybe all) use anycast addressing for their services. For example, if you and I both used Google DNS from different parts of the country our queries would go to different servers. Servers that are closer to us - in internet terms. The image.tmdb.org service is highly distributed over multiple cloud and CDN providers across the US and maybe even the world. Another feature of DNS services is to respond with the most advantageous addresses for our queries. So a DNS server closer to you is going to respond with CDN/cloud endpoints that are also closer to you. Below are the stats from 500 nslookups from four of the big DNS players. There are a few things you can take from these: 1. They all respond differently. 2. There is overlap in their responses. 3. There may be uniqueness in their responses. 4. Trying a different one might exclude or reduce responses that send your connection to a service with the cert(s) that are failing for your server. image.tmdb.org.cloudflare Total: 153 IPv6: 138 IPv4: 15 image.tmdb.org.google Total: 138 IPv6: 129 IPv4: 9 image.tmdb.org.opendns Total: 164 IPv6: 144 IPv4: 20 image.tmdb.org.quad9 Total: 133 IPv6: 102 IPv4: 31 Total unique: 227 Unique IPv6: 191 Unique IPv4: 36 1
adam.niescierowicz 6 Posted July 28, 2023 Posted July 28, 2023 Quote Do you have dates on those files? Not important but I'm curious. Yes, first column format: `year.month.day` Quote 2018.09.09 E6A3B45B062D509B3382282D196EFE97D5956CCB.pfx 2019.12.21 33E4E80807204C2B6182A3A14B591ACD25B5F0DB.pfx 2020.12.31 48504E974C0DAC5B5CD476C8202274B24C8C7172.pfx Quote Regarding those files, what you can do with them is: 1. Stop the emby server. 2. Move those files to another directory, doesn't matter where as long as they're gone from this one. 3. Start the emby server. Done Quote Back to DNS I thnik it can be easy checked. I will install DNS cache server so for 2-3 days one domain will be having the same ip address(from cache server). If problem is with DNS when emby can't receive file also wget shouldn't.
Q-Droid 1011 Posted July 28, 2023 Posted July 28, 2023 (edited) 1 hour ago, adam.niescierowicz said: Yes, first column format: `year.month.day` 2018.09.09 E6A3B45B062D509B3382282D196EFE97D5956CCB.pfx 2019.12.21 33E4E80807204C2B6182A3A14B591ACD25B5F0DB.pfx 2020.12.31 48504E974C0DAC5B5CD476C8202274B24C8C7172.pfx I thnik it can be easy checked. I will install DNS cache server so for 2-3 days one domain will be having the same ip address(from cache server). If problem is with DNS when emby can't receive file also wget shouldn't. Yeah, those files are pretty old. I wouldn't move on DNS quite yet. Let's see if the pfx removal makes a difference. Caching could change things but in reality unless you override the DNS response TTL it will not be days and most cases a few minutes. Unless you mean to set static entries for this domain. As I said before the DNS change was more of an experiment to see if the failure rate was different from one resolver to another but not a fix or the way forward. The actual problem is with the certs presented by some of the cloud/CDN service endpoints and why it's intermittent. Without detailed connection and handshake info in the logs it's a guess as to which of them was failing. Edited July 28, 2023 by Q-Droid
Luke 42245 Posted August 3, 2023 Posted August 3, 2023 @adam.niescierowiczare you still having an issue with this?
adam.niescierowicz 6 Posted August 3, 2023 Posted August 3, 2023 3 hours ago, Luke said: @adam.niescierowiczare you still having an issue with this? Just checked, after changing certs errors didn't appear. Looks good. 1
ChaoOos 2 Posted August 5, 2023 Posted August 5, 2023 On 8/3/2023 at 8:21 AM, adam.niescierowicz said: Just checked, after changing certs errors didn't appear. Looks good. same for me
