ipv6 unique local addresses connect as remote connections not local.
Go to solution Solved by echoxxzz,
My Windows PC hosting Emby server has IPv6 enabled.
It has an ipv6 globally unique address that comes from the ISP assigned using SLAAC and a static Unique Local Address (fdd0::45/32) that I have assigned. As well it has a private static ipv4 address (192.168.10.45/24).
In my local DNS server i have an ipv4 A record (192.168.10.45/24) and an ipv6 AAAA record (fddd0::45/32) assigned to the name of the Emby server.
In the Emby server admin console I entered the ipv4 private subnet (192.168.0.0/24) and the ipv6 unique local subnet (fdd0::/32) as the "Local Nets" but Emby server always thinks connections are remote if a device on my local LAN connects using ipv6.
How can I get Emby server to recognize the connections from the unique local addresses as local and not remote? Is it possible that I am entering the ipv6 subnets incorrectly?
  • Solution
AH damn I figured it out. I had one to many colons.
  • Thanks 1
Thanks for following up.
