howieT82 2 Posted November 3, 2022 Posted November 3, 2022 Hello Most of the content I have in my libraries have missing images for the cast and crew as shown in the picture any ideas on how to fix this?
Luke 42186 Posted November 3, 2022 Posted November 3, 2022 Hi there, please attach the emby server log from when this happened. THanks.
howieT82 2 Posted November 3, 2022 Author Posted November 3, 2022 I'm not sure when it happened I know it was maybe a month or so ago I checked the logs page in the advanced menu and it only goes back to 10/30/22
Happy2Play 9800 Posted November 4, 2022 Posted November 4, 2022 Did you change anything with your metadata path?
howieT82 2 Posted November 4, 2022 Author Posted November 4, 2022 No I didn't change anything should I rescan the metadata folder?
Luke 42186 Posted November 4, 2022 Posted November 4, 2022 Try refreshing the metadata on the movie and see if that helps.
Happy2Play 9800 Posted November 4, 2022 Posted November 4, 2022 20 minutes ago, howieT82 said: No I didn't change anything should I rescan the metadata folder? You could but a server log would provide more information and possibly a browser console log if there are errors.
howieT82 2 Posted November 4, 2022 Author Posted November 4, 2022 Is there a way to find that specific log?
howieT82 2 Posted November 4, 2022 Author Posted November 4, 2022 17 minutes ago, Luke said: Try refreshing the metadata on the movie and see if that helps. Its not just that movie its pretty much everything
Luke 42186 Posted November 4, 2022 Posted November 4, 2022 6 minutes ago, howieT82 said: Its not just that movie its pretty much everything Can you please try it anyway and let us know the result? Thanks.
Luke 42186 Posted November 4, 2022 Posted November 4, 2022 7 minutes ago, howieT82 said: Is there a way to find that specific log? If it happened a month ago then it's going to be hard to figure out what happened. At this point you'll have to just repair, but if you can get it to happen again with a new title, then that will tell us more.
Happy2Play 9800 Posted November 4, 2022 Posted November 4, 2022 Can you provide the current server log showing when you navigate to a item and the images are missing.
