stefsegers 9 Posted November 3, 2022 Posted November 3, 2022 Hi Guys, When I go to https://app.emby.media I need to login to my Emby account. When I do this, I am presented with my server, but when I click my server I am getting an error message that I need to upgrade to the latest version. I installed the latest version first, but same problem. Then I installed the latest Beta which has a higher number, but same issue. When I go to my Synology DSM and startup Emby from there, everything seems okay. Normally it was possible to use the app.emby.media url... what am I doing wrong here?
Luke 42243 Posted November 3, 2022 Posted November 3, 2022 Hi, have you setup https on your emby server? If not then you'll need to use the http version of app.emby.media
stefsegers 9 Posted November 3, 2022 Author Posted November 3, 2022 Hi Luke, thanks for your quick reply! When I startup Emby from my DSM and check on the Dashboard: Draait op http poort 8096. In-Home (LAN)-toegang: http://10.0.0.50:8096 Externe (WAN) access: http://xx.xx.xx.xx:8096 On https://app.emby.media/#!/startup/selectserver.html I can see my server with the same http://xx.xx.xx.xx:8096 So not sure if I have set it up correctly?
stefsegers 9 Posted November 3, 2022 Author Posted November 3, 2022 wow you are really quick! When I open up this link (http) I am getting in the same windows and when I click on my server I get the same error Deze Emby Server moet worden bijgewerkt. Om de laatste versie te downloaden, gaat u naar <a href="https://emby.media">https://emby.media</a>
Luke 42243 Posted November 3, 2022 Posted November 3, 2022 What version of Emby Server are you running?
stefsegers 9 Posted November 3, 2022 Author Posted November 3, 2022 Because I got the message that I need to upgrade I tried the latest version, but did not help.. then I installed this version Version 4.8.0.16 beta Same problems
Luke 42243 Posted November 3, 2022 Posted November 3, 2022 Strange. Can you try it again and capture the contents of the browser debug console?
stefsegers 9 Posted November 3, 2022 Author Posted November 3, 2022 Yes I want to help.. I am in Chrome -> option + CMD + J -> refresh the page.... but nothing is there. I think I am in the wrong devtools?!
Luke 42243 Posted November 3, 2022 Posted November 3, 2022 Right, now that you've refreshed the page, please try it again with the debugger open. Thanks.
Luke 42243 Posted November 3, 2022 Posted November 3, 2022 because you have a filter applied in the console that you need to remove. click the x next to canonical.
stefsegers 9 Posted November 3, 2022 Author Posted November 3, 2022 ow hahaha.. did no know that.. thanks for the help! Tools failed to load source map: Could not load content for chrome-extension://gighmmpiobklfepjocnamgkkbiglidom/browser-polyfill.js.map: System error: net::ERR_FILE_NOT_FOUND app.js?v=4.7.8.20:1 Setting require baseUrl to http://app.emby.media alameda.js?v=4.7.8.20:1 getJsUr This is what I am getting
Luke 42243 Posted November 3, 2022 Posted November 3, 2022 Are you sure that is the complete contents? I don't know what that browser-polyfill thing is but I would suggest removing chrome extensions and then trying again.
stefsegers 9 Posted November 3, 2022 Author Posted November 3, 2022 that that's it indeed. I have disabled AdBlock + LT (Language Tool) extentions Setting require baseUrl to http://app.emby.media. app.js?v=4.7.8.20:1 getJsUrlWithExtension: modules/browser.js?v=4.7.8.20. alameda.js?v=4.7.8.20:1 This is on the webpage: Deze Emby Server moet worden bijgewerkt. Om de laatste versie te downloaden, gaat u naar <a href="https://emby.media">https://emby.media</a> 1
Luke 42243 Posted November 3, 2022 Posted November 3, 2022 OK, I'm not sure why that matters, but @cayars can look at reporting a false positive to AdBlock. Thanks.
stefsegers 9 Posted November 3, 2022 Author Posted November 3, 2022 great! Curious what the problem is 1
Carlo 4561 Posted November 4, 2022 Posted November 4, 2022 If you click on the adblock panel, far right in the dev console do you see anything listed there? What version of adblock do you have installed? I'll try and duplicate your issue. Carlo
stefsegers 9 Posted November 4, 2022 Author Posted November 4, 2022 Hi @cayars, thanks for getting back to me. I installed the latest adBlock … but the problem also exists with all extensions disabled
Carlo 4561 Posted November 4, 2022 Posted November 4, 2022 What's the specific version number and region (country) you're in? I ask because I'm not able to reproduce this so I want to make sure I'm running the same version of adblock as you. Does this happen every time you try to use it with http://app.emby.media ? Doesn't happen when you enter http://10.0.0.50:8096 from your own LAN correct? Have you tried any other computer or even a different browser on the same computer? Please send me a Private Message (hover over my avatar) with your real remote address and I'll test connecting to your login page. Carlo
stefsegers 9 Posted November 5, 2022 Author Posted November 5, 2022 Thanks for getting back to me! @cayars I am using Version 4.8.0.16 beta and I live in The Netherlands AdBlock chrome extension is disabled It always worked.. but since a few weeks it doesn't anymore. I have no idea if I changed something.. I am not aware I have changed anything. The only thing I can think of is that I deleted my Chrome Cache When I use the local IP http://10.0.0.50:8096 it works seamless So just tested on my laptop instead of the Mac Mini.. and that does work?!?
Carlo 4561 Posted November 6, 2022 Posted November 6, 2022 On 11/3/2022 at 4:05 PM, Luke said: Are you sure that is the complete contents? I don't know what that browser-polyfill thing is but I would suggest removing chrome extensions and then trying again. Had the feeling that would be the case. It's the machine your using to do the tests that's having the error, it seems. Pollyfill is a service & library that devs use to get information about the browser. This isn't about security and you but the browser itself. Code libraries getting ready to run ask the browser "What do you support" and when they don't get any information back they can have pollyfill intervene and try to figure out what you are. They may try a bunch of things until they figure out the browser, the rough version, what's turned on and what's not. This is the bad part of "add blocking" software that take things too far. If the library can't' communicate with your browser then you're normally dead from that point rendering anything. In an attempt to rid you of ads and tracking they remove so much info in the browser settings that even when they aren't running sites have trouble just figuring out what you need to render the page. I would completely remove the plugin, then go into Chromes settings and choose "Reset and clean up" at the bottom of the list on the left menu. Then choose "Restore settings to their original defaults". You can do a backup first or create a windows restore point right before resetting Chrome so you could revert back if needed. Carlo
stefsegers 9 Posted November 7, 2022 Author Posted November 7, 2022 Thanks Carlo for your reply. Just tried Safari without Ad-Block and this has the same problems on my Mac Mini. It looks like it is computer based somehow and not only Chrome.
Carlo 4561 Posted November 7, 2022 Posted November 7, 2022 Please follow the steps I asked you to try IP & name as well as supplying the server logs. Appreciated, Carlo
stefsegers 9 Posted November 7, 2022 Author Posted November 7, 2022 I opened up both 10.0.0.50:8096 and http://app.emby/media Here's the server log embyserver.txt
