Tsch3ns 16 Posted November 3, 2022 Posted November 3, 2022 Hello, I tried to configure LiveTV by using some paths from https://github.com/iptv-org/iptv#playlists and adapting the start page in the settings in order to show Live TV. Although the channel list seems to be recognized correctly (I can see the list in the settings), I dont see any channel on the emby start page. I have no experience with LiveTV, maybe I got it wrong and the way I tried to set it up is completely wrong? Thx for any help, Tschens
Tsch3ns 16 Posted November 3, 2022 Author Posted November 3, 2022 I need to add that I am running the server version 4.8.0.15beta and that the m3u lists work fine in VLC on my desktop PC:
Luke 42243 Posted November 3, 2022 Posted November 3, 2022 Hi, did you try going into the live TV section? That's where you'll see the channels.
Tsch3ns 16 Posted November 3, 2022 Author Posted November 3, 2022 I cannot find a Live TV section. Where should it be located?
Solution Luke 42243 Posted November 3, 2022 Solution Posted November 3, 2022 Where are you looking for it? Click Home in the top left, then you'll see it on the next screen, provided that you've imported channels, and provided that you've granted the logged in Emby user access to Live TV. 1
Tsch3ns 16 Posted November 3, 2022 Author Posted November 3, 2022 (edited) erase Edited November 3, 2022 by Tsch3ns
Tsch3ns 16 Posted November 3, 2022 Author Posted November 3, 2022 (edited) Problem solved. None of my users had the rights (this was the ONLY setting i did not check for many hours of testing). Now its there! Thanks Luke!! Edited November 3, 2022 by Tsch3ns 1
