charloe 2 Posted October 31, 2022 Posted October 31, 2022 On my computer the emby server works fine but when i try to go onto my apple tv or Samsung tv I can never connect to my emby server. I'm not very good at computers so the answer could be simple but im not too sure.
SamES 1084 Posted October 31, 2022 Posted October 31, 2022 What port number are you trying to connect with? Are you using http or https?
SamES 1084 Posted November 1, 2022 Posted November 1, 2022 I'm assuming all devices are on the same network as the server. Correct? On the server, in the Network settings, what do you have the 'Secure Connection Mode' option set to? Marke sure the ip/address you are entering on the device matches what's on the Dashboard on the server.
charloe 2 Posted November 1, 2022 Author Posted November 1, 2022 yup, all devices on the same network i made sure the ip is the same when i was trying to connect last night out right now but i will tell you the secure connection mode when im home
Solution charloe 2 Posted November 1, 2022 Author Solution Posted November 1, 2022 (edited) my secure connection mode is disabled EDIT : this reddit post just solved my problem Edited November 1, 2022 by charloe 1 1
