Przemek 70 Posted October 31, 2022 Posted October 31, 2022 Hi, from four or three days I noticed on my Android C+ box that when I change language I get error: `Too many errors.Giving up.` I must reboot device to watch something again on Emby. embyserver.txt
Solution Luke 42245 Posted November 1, 2022 Solution Posted November 1, 2022 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
Przemek 70 Posted November 1, 2022 Author Posted November 1, 2022 7 hours ago, Luke said: Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks. Thanks, now works OK. 1
