SamES 1084 Posted November 25, 2022 Posted November 25, 2022 @Yangorang, @ambou75, @gLuTaMa, can you please let me know your TV model numbers. Using the latest USB beta, can one of you please turn on Stats for nerds while playing a file that won't allow you to switch audio tracks, then post a picture of what's displayed?
ambou75 1 Posted November 30, 2022 Author Posted November 30, 2022 (edited) Hi @SamES, my T model number is Samsung QLED QE55Q83B 4K 2022 (Model Code QE55Q83BATXXC). Version 1.4.8 of Tizen App. I chose English Audio Language and French Subtitle. And it's French Audio language (the first in the list) i hear Edited November 30, 2022 by ambou75
SamES 1084 Posted November 30, 2022 Posted November 30, 2022 Thanks, that's interesting. When the next USB release comes out, which should be soon, can you please repeat this same test with the same movie. it will have different information displayed, but it will also be helpful. I suspect I know what is wrong here, but we need to confirm with the next version.
SamES 1084 Posted December 17, 2022 Posted December 17, 2022 On 01/12/2022 at 00:29, ambou75 said: Hi @SamES, my T model number is Samsung QLED QE55Q83B 4K 2022 (Model Code QE55Q83BATXXC). Version 1.4.8 of Tizen App. I chose English Audio Language and French Subtitle. And it's French Audio language (the first in the list) i hear Hi @ambou75, can you please repeat this same test with the same file using 1.4.9. It should give you different info in SFN. Thanks
gLuTaMa 1 Posted December 17, 2022 Posted December 17, 2022 Hi, yes, unfortunately same issue with 1.4.9. Choose German and hear englisch. Hope it helps you, too.
ambou75 1 Posted December 18, 2022 Author Posted December 18, 2022 Hi @SamES, Same test with Tizen 1.4.9 and the same movie, with nerd option. I have the same issue. Do you have any leads ? Thank's
SamES 1084 Posted December 20, 2022 Posted December 20, 2022 This looks like the same issue we are seeing with 2021 models. I have added a work-around for the next version which will switch audio tracks on the server for 2022 models as well 1
Madd_Mugsy 2 Posted January 14, 2023 Posted January 14, 2023 Just installed the latest version of the tizen emby app from this week, and unfortunately this issue is still occurring on my 2022 model Samsung TV (qn90b). Is there a setting in the app that I need to change or something?
SamES 1084 Posted January 14, 2023 Posted January 14, 2023 49 minutes ago, Madd_Mugsy said: Just installed the latest version of the tizen emby app from this week, and unfortunately this issue is still occurring on my 2022 model Samsung TV (qn90b). Is there a setting in the app that I need to change or something? Please make sure your TV has the latest firmware update. You might need to go to the Samsung downloads website for you model and install it via USB as the OTA updates can take quite a while to be deployed. Samsung have fixed this issue in the recent firmware update (released late last year)
gLuTaMa 1 Posted January 15, 2023 Posted January 15, 2023 Hi, the issue is solved. Perfect thank you very much. 1
ambou75 1 Posted January 15, 2023 Author Posted January 15, 2023 Hello, The issue is solved for audio language but now i can't choose subtitles in the liste. I only can choose subtitles when i watch the movie with shortcuts.
SamES 1084 Posted January 16, 2023 Posted January 16, 2023 14 hours ago, ambou75 said: I only can choose subtitles when i watch the movie with shortcuts. I'm not quite sure what this means. What do you mean by shortcuts?
Madd_Mugsy 2 Posted January 29, 2023 Posted January 29, 2023 (edited) On 1/14/2023 at 1:20 PM, SamES said: Please make sure your TV has the latest firmware update. You might need to go to the Samsung downloads website for you model and install it via USB as the OTA updates can take quite a while to be deployed. Samsung have fixed this issue in the recent firmware update (released late last year) I downloaded the 1420.9 firmware from the samsung site, tried to install it via usb, and the tv says this version is already installed. Yet I still have the issue. I've also got an issue where the sound pops and the audio + video slowly go out of sync... I'm going to see if there's a newer version than 1.50 of the Emby app to try out. Edit: There isn't. Next step I guess is to try resetting the whole TV. No issues when watching on Windows or Android. Edited January 29, 2023 by Madd_Mugsy
SamES 1084 Posted January 29, 2023 Posted January 29, 2023 7 hours ago, Madd_Mugsy said: I downloaded the 1420.9 firmware from the samsung site, tried to install it via usb, and the tv says this version is already installed. Yet I still have the issue. I've also got an issue where the sound pops and the audio + video slowly go out of sync... I'm going to see if there's a newer version than 1.50 of the Emby app to try out. Edit: There isn't. Next step I guess is to try resetting the whole TV. No issues when watching on Windows or Android. You can try a TV reset, but you might have a different issue. Let's go through a specific example. Can you post the logs, media info and details of what you're testing and expecting to occur?
