nodiaque 62 Posted October 30, 2022 Posted October 30, 2022 Hello, I'm running into issue since about 2 weeks. My home screen will start showing "latest" of library I unchecked. Then when I go into settings, home screen, I see them check. I uncheck them, logout, login. Now, it display them in continue watching and the library order are all scramble. If I go back in home screen setting and change the order, it doesn't save! The only way I found to temporary remediate is to logout, go on my android phone, reconfigure everything and them go back on the tv. But it's a temp fix cause it will sooner or later start showing the latest from these library and I'll have to redo all over again. Thank you
Luke 42237 Posted October 30, 2022 Posted October 30, 2022 Hi, it's resolved for the next update to the emby LG app. Thanks.
Tataie 1 Posted November 12, 2022 Posted November 12, 2022 Hi, can we have a download link of the app for the ones who can install it manualy or upload it to https://github.com/webosbrew/apps-repo, thank you ! 1
Manuel 1 Posted November 16, 2022 Posted November 16, 2022 On 11/12/2022 at 5:10 PM, Tataie said: Hi, can we have a download link of the app for the ones who can install it manualy or upload it to https://github.com/webosbrew/apps-repo, thank you ! Yes please :)
Luke 42237 Posted November 17, 2022 Posted November 17, 2022 We have a new release in LG review now, so hopefully not too much longer. Thanks.
Solution Luke 42237 Posted December 26, 2022 Solution Posted December 26, 2022 Emby for LG TV's 1.0.37 has been released. Stay tuned to the blog for the release announcement. Can you please try out the new update and let us know how it compares? Thanks !
