tarmer 2 Posted October 29, 2022 Posted October 29, 2022 Greetings- I am a new Emby user and am having an issue that I have tried to read in the forums but not sure i found the solution - if there am happy to read again.. I am using a synology ds220+ with HDHR flex 4k and an AppleTV (4k) - with OTA I can get emby up and running, finds the guide etc… but when I select a channel and press run - the picture loads fairly quickly but it then freezes and will not play - if i scroll ahead it will sometimes start and play from there with no further issues- but change channel and you have to start it all again. Now (and I know everyone does this) but this is not an issue with either Plex or Channels - I am not comparing the features or anything to each other other than this same setup works fine on other server software. I would love to see if i can get this resolved on Emby - can you tell me what i need to provide you to see if we can find the issue Thank You in advance
Luke 42243 Posted October 29, 2022 Posted October 29, 2022 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
tarmer 2 Posted October 29, 2022 Author Posted October 29, 2022 This is what i found - let me know if this is what is needed embyserver-63802634886.txt ffmpeg-transcode-3bbac86a-b4a2-4efc-9fe4-38f239144a61_1.txt hardware_detection-63802631597.txt
tarmer 2 Posted October 31, 2022 Author Posted October 31, 2022 I assume patience is the solution, but as I paid for a premiere license - I would hope I could get faster response…. I understand I am not the only one here nor the only paying customer- but In order to try the DVR and live tv solution- I had to but at least a one month license - as noted I would love to get this resolved as I responded as soon as the request was given. in the end it is not the end of the world either way - if I can’t get the product to work I just won’t use it - not really the preference but i suppose an option
