dorinandreescu 7 Posted October 28, 2022 Posted October 28, 2022 Hello. I have a Mikrotik ax2, with mapped port of my server. The issue appear when I try to login through Emby.media, with registered email. I get user or password wrong. If I put my DDNS everything works great, but when I try through Emby Connect Media I can`t login. What I have do wrong? Thanks!
GrimReaper 4893 Posted October 28, 2022 Posted October 28, 2022 2 hours ago, dorinandreescu said: Hello. I have a Mikrotik ax2, with mapped port of my server. The issue appear when I try to login through Emby.media, with registered email. I get user or password wrong. If I put my DDNS everything works great, but when I try through Emby Connect Media I can`t login. What I have do wrong? Thanks! Have you (optionally) linked your local user to Connect user (Settings>User>edit user)?
dorinandreescu 7 Posted October 28, 2022 Author Posted October 28, 2022 2 hours ago, GrimReaper said: Have you (optionally) linked your local user to Connect user (Settings>User>edit user)? yes. for every user that i have. linked by mail you say?
GrimReaper 4893 Posted October 28, 2022 Posted October 28, 2022 (edited) Yes, in user settings. What do you by mean "every user"? Edited October 28, 2022 by GrimReaper
dorinandreescu 7 Posted October 28, 2022 Author Posted October 28, 2022 7 hours ago, GrimReaper said: Yes, in user settings. What do you by mean "every user"? i have more users with emby medua connect accounts. everyone has email address added.
