GrayAgain 0 Posted October 27, 2022 Posted October 27, 2022 So I installed a nvidia quadro p400 and I havent exposed the card in the docker container yet since its a temp card but now I am getting the hardware_detection log with errors do i have to worry about this or no. Also when i installed the card Seeking and fast forward 10 seconds would reset the video to the beginning if not on local. OS: UNRAID version 6.11.1 Emby installed type: Docker Container hardware_detection-63802400003.txt
GrayAgain 0 Posted October 27, 2022 Author Posted October 27, 2022 2 hours ago, Luke said: Hi there, are you experiencing a problem? When not on local network I cant skip ahead it just resets the video to the beginning. Makes it so i cant skip to where i was. Here are the log files embyserver (2).txt ffmpeg-directstream-45973b90-6b6d-4813-849f-0cfc8df96011_1.txt
GrayAgain 0 Posted October 27, 2022 Author Posted October 27, 2022 8 minutes ago, Luke said: Are you using a reverse proxy? yes I am Reverse proxy with Traefik. this wasn't an issue until recently
Solution Luke 42245 Posted November 2, 2022 Solution Posted November 2, 2022 @GrayAgain and you're saying it's fine on the local network? If that's the case, then please take a look at this topic and see if the knowledge learned here helps you at all: Thanks !
