elche27 3 Posted October 26, 2022 Posted October 26, 2022 Good Morning to all! A quick question, what should be daily or week maintenance to a server emby over LINUX?? Thank you in advance!
EODCrafter 181 Posted October 26, 2022 Posted October 26, 2022 (edited) 27 minutes ago, elche27 said: Good Morning to all! A quick question, what should be daily or week maintenance to a server emby over LINUX?? Thank you in advance! Maintenance on What?.....Emby or the Linux OS? sudo apt update, apt upgrade, apt autoclean, apt autoremove, reboot, if it tells you to.... Edited October 26, 2022 by EODCrafter
EODCrafter 181 Posted October 26, 2022 Posted October 26, 2022 Once @Lukeputs out new server upgrade, wget new version, shutdown server, and install new version as shown in directions.....
elche27 3 Posted October 26, 2022 Author Posted October 26, 2022 Maintenance on Emby server, for example: erase logs because use too much space and slow emby server...iam not telling that happens...is an example... Restart emby server every week because cache get full....i really dont know...just asking if need some maintenance to avoid wrong or slow functions. I ask because yesterday, my users couldnt watch live tv...i must restart it to solve it... Server is poweredge R540 with 96gb of ram
Luke 42245 Posted October 26, 2022 Posted October 26, 2022 4 hours ago, elche27 said: Maintenance on Emby server, for example: erase logs because use too much space and slow emby server...iam not telling that happens...is an example... Restart emby server every week because cache get full....i really dont know...just asking if need some maintenance to avoid wrong or slow functions. I ask because yesterday, my users couldnt watch live tv...i must restart it to solve it... Server is poweredge R540 with 96gb of ram Hi, log files older than three days old are automatically deleted by the server.
Happy2Play 9812 Posted October 26, 2022 Posted October 26, 2022 Only rogue issue that happens to some is Transcode-temp not always cleaned up so a restart is required to clear the folder. But some have created scripts to do it. But normally nothing needs to be done unless you are experiencing a specific issue.
EODCrafter 181 Posted October 27, 2022 Posted October 27, 2022 (edited) 18 hours ago, Happy2Play said: Only rogue issue that happens to some is Transcode-temp not always cleaned up so a restart is required to clear the folder. But some have created scripts to do it. But normally nothing needs to be done unless you are experiencing a specific issue. What would be the script to restart server? sudo service emby-server restart ? Wait, that would require Auth.....cron root would work, right? sudo crontab -e Edited October 27, 2022 by EODCrafter
Happy2Play 9812 Posted October 27, 2022 Posted October 27, 2022 11 hours ago, EODCrafter said: What would be the script to restart server? sudo service emby-server restart ? Wait, that would require Auth.....cron root would work, right? sudo crontab -e Sorry not knowledgeable on Linux platforms. @Lukeis there a graceful service restart? Testing this in Windows, restart or stopping the service appears to kill the session looking at the log unless that is just do to NSSM.
Luke 42245 Posted October 27, 2022 Posted October 27, 2022 We do use a mechanism with the. Net runtime to get notified of being requested to close by the OS, but it may not work like that on all platforms.
EODCrafter 181 Posted October 28, 2022 Posted October 28, 2022 10 hours ago, Luke said: We do use a mechanism with the. Net runtime to get notified of being requested to close by the OS, but it may not work like that on all platforms. Huh? This is under the "Linux" subforum.
elche27 3 Posted October 29, 2022 Author Posted October 29, 2022 Good Morning, 2 day after the issues commented, today again users cant watch channels on LIFETV...again i restarted emby and "solved it"...can help me with this, maybe is an error on me or should i cron a restart every 2 days? or add schedule restar as feature¨? i aprreciatte all help!! Thank in advance attched fileshardware_detection-63802641492.txtffmpeg-transcode-db8395d2-9e19-4364-8c06-863fdbdfd205_1.txtembyserver-63802641487.txt
EODCrafter 181 Posted October 29, 2022 Posted October 29, 2022 (edited) 11 minutes ago, elche27 said: Good Morning, 2 day after the issues commented, today again users cant watch channels on LIFETV...again i restarted emby and "solved it"...can help me with this, maybe is an error on me or should i cron a restart every 2 days? or add schedule restar as feature¨? i aprreciatte all help!! Thank in advance attched fileshardware_detection-63802641492.txtffmpeg-transcode-db8395d2-9e19-4364-8c06-863fdbdfd205_1.txtembyserver-63802641487.txt What Kind of TV is This, IPTV? How many Streams do you have available? Do they allow you to "share" your Streams with other people? Numerous times on my IPTV, it freezes up and I have to reload the channel. Just the nature of IPTV I'm afraid. Might also check if Transcoding Temp is filling your hard drive on the server. I've seen this also. We have made a request to @Luketo be able to disable transcode temp file but it hasn't been implemented yet. Edited October 29, 2022 by EODCrafter
elche27 3 Posted October 29, 2022 Author Posted October 29, 2022 Thank Mr EOD 4 ur answer All channels go freeze so i must restart emby server, in my previous comment i attached a hardware log, i think this generate when the error come out. No iptv channel or sharing, Due to the requirements for that type of infrastructure i need, I have not chosen it yet, apart from my pocket or my country is not yet ready to carry it out just normal lifetv from dvbs network to tvbox emby app Infraestructure Poweredge R550 server with 96 GB ram TVheadend 4.2.8 TBS6909 with 2 of 4 transponder working 103 channels and most EPG workings 4 network DVB-S2 EMBY 4.7.8 - PREMIERE LIFETIME tvheadend plugging as source of some channels / M3U8 source as source of some channels Users networks is over Fiber optic TIPS: emby and tvheadend are on the same server, no dockers! 1
