MickeyRat 13 Posted October 25, 2022 Posted October 25, 2022 (edited) First this is on an Nvdia Shield not a TV but, I wasn't sure where else to put it. I have Emby Server running on a server on my LAN with Emby Client running on the Nvidia Shield. It appears to work for playback but, the guide won't load on the Nvidia Shield. It just spins for along time then displays an error message. The only thing this will stop me from doing is live TV which I rarely need to do. It would be nice to schedule recordings through the TV though. Any suggestions? Edited October 25, 2022 by MickeyRat
Solution ebr 16337 Posted October 25, 2022 Solution Posted October 25, 2022 Hi. How many channels do you have? Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
MickeyRat 13 Posted October 26, 2022 Author Posted October 26, 2022 Since you asked, I have 42 channels but, that wasn't the problem. I side loaded the APK from the link you provided and that solved the problem. Thanks!!! 1
