Luke 42150 Posted October 1, 2024 Posted October 1, 2024 51 minutes ago, charlieego said: I found the problem by double-checking. When I uninstall InfuseSync ver1.5(plugin) and run the “Episode Refresh” plugin, emby server does not freeze. Or if I run emby server under 4.8.4.0, install InfuseSync 1.4.2, and run the “Episode Refresh” plugin then the emby server does not freeze. InfuseSync 1.5 seems to conflict with the “Episode Refresh” plugin? Should I approach the infuse team? embyserver-63863429402.txt 57.75 kB · 0 downloads Does the whole server process stop?
charlieego 1 Posted October 1, 2024 Posted October 1, 2024 Yes,only thing i can do is end the process and open the emby server again. it is not possible to restart the emby server via the taskbar icon.
Luke 42150 Posted October 1, 2024 Posted October 1, 2024 29 minutes ago, charlieego said: Yes,only thing i can do is end the process and open the emby server again. it is not possible to restart the emby server via the taskbar icon. And what happens if you remove the infuse plugin, restart the server, and try again?
charlieego 1 Posted October 1, 2024 Posted October 1, 2024 After my attempts to uninstall the infuse plugin and restart the emby server I was able to run Episode Refresh's scheduled tasks as usual. I recently updated the emby server, and the infuse plugin updated automatically, and then this happened.
Luke 42150 Posted October 1, 2024 Posted October 1, 2024 8 minutes ago, charlieego said: After my attempts to uninstall the infuse plugin and restart the emby server I was able to run Episode Refresh's scheduled tasks as usual. I recently updated the emby server, and the infuse plugin updated automatically, and then this happened. I would run it more times and see if the results are consistent. It could be coincidence that the problem occurs with Infuse installed. Perhaps if you run it enough times without Infuse, you'll see it happen again at some point.
charlieego 1 Posted October 1, 2024 Posted October 1, 2024 24 minutes ago, Luke said: I would run it more times and see if the results are consistent. It could be coincidence that the problem occurs with Infuse installed. Perhaps if you run it enough times without Infuse, you'll see it happen again at some point. Please see the video. I ran the scheduled task 5 times without the infuse plugin installed and embyserver still runs fine. And I set it to run once a day, which is usually not a problem. I restarted emby server after installing the infuse plugin to run the scheduled task and embyserver crashed immediately. 2024-10-02 04-25-27.mp4 1
milesbenson 1 Posted February 27 Posted February 27 Same here, Emby Version 4.9.3.0, InfuseSync 1.5.2.0 From the moment i installed Episode Refresh and started the task (at night, 3am), Emby crashed. InfuseSync disabled, all good. As i definitely need InfuseSync, i cannot use the refresher.
