STR8 74 Posted October 24, 2022 Posted October 24, 2022 I was wondering if you may be able to help me get Emby back up and running or point me in the right direction. So, yesterday I just installed the new plugin Top Picks, but I think the issue is I was so far behind on the emby server OS version I had to update to version 4.7.8.0 allow the new plugins to work. After updating Emby I can get into the emby server from any location or device I just keep getting the server can't be reached as seen below. It seems the only way to get into the emby server is to restart the nas and then it works fine then for whatever reason it will stop again timeout or falls a sleep don't know have any others been having an issue like this? Thanks in advance for any and all help. Terramaster version I also get this (don't know if this has something to do with it
Luke 42237 Posted October 24, 2022 Posted October 24, 2022 @STR8can you please provide the emby server log? Thanks.
STR8 74 Posted October 24, 2022 Author Posted October 24, 2022 No worries and thank you for looking at this for me Luke is there a certain log you might be looking for if so please let me know but I attached 1 from yesterday and 1 from today. embyserver.txt embyserver-63802119733.txt
Happy2Play 9811 Posted October 24, 2022 Posted October 24, 2022 As mentioned in the Top Pick plugin topic the AutoCollection (version grouping) plug and Top Picks do not play well together. So when enter a item on Top Picks list there is a memory leak that will eventually kill the system. So currently you have to remove one plugin or the other. Or at least that is what I have seen in my testing.
STR8 74 Posted October 24, 2022 Author Posted October 24, 2022 Yes, understood @Happy2Play I have removed the top picks plugin yesterday in hopes that when the scheduled task ran last night it would finish any missed updates and so on so thought I would ask the professionals to take a look and see if I did something or missed something as I'm not one lol!
Luke 42237 Posted October 24, 2022 Posted October 24, 2022 There's nothing obvious here. I would suggest removing all third party plugins, then restart the server and see how that compares. Thanks.
STR8 74 Posted October 24, 2022 Author Posted October 24, 2022 Will do and sorry if I wasted anyone's time
STR8 74 Posted October 25, 2022 Author Posted October 25, 2022 Just wanted to check-in and let you know everything is fine thanks again. 1
Happy2Play 9811 Posted October 26, 2022 Posted October 26, 2022 9 hours ago, STR8 said: Just wanted to check-in and let you know everything is fine thanks again. Did you identify anything causing the issue?
STR8 74 Posted October 26, 2022 Author Posted October 26, 2022 I think you were right it was just the Top Picks Plugin. I deleted it and let the server run its normal scans or tasks and it's all good. I haven't had any issues logging in so far at all.
Happy2Play 9811 Posted October 26, 2022 Posted October 26, 2022 @STR8 A guess even though you deleted the autocollection (auto grouping) plug the items are still grouped and Top Picks still has the memory leak. Pretty sure I saw the same results if I remember correctly. You have to go to original items that are grouped in their actual library and you should see a button to Split Apart down by Media Info.
STR8 74 Posted October 26, 2022 Author Posted October 26, 2022 Hey Happy2Play I deleted the top picks plugin not the auto grouping plugin I will most likely wait for it be fixed to play nice with the others plugins but thanks for that information it's appreciated.
