Bazzu85 22 Posted October 24, 2022 Posted October 24, 2022 (edited) Hi, here's the media on server (3 srt subs): Here's the offline one: First at all, playing media on server from web with italian subtitles works. the same from theater doesn't (edit after a while the subs appear). Playing the offline version with the embedded subtitle doesn't work. Playing the offline version with the VTT subs works.. questions: - is this a specific theater behaviour to generate the VTT files? - why the srt embedded doesn't work for offline content? thx Edited October 24, 2022 by Bazzu85 fixed title
Luke 42237 Posted October 24, 2022 Posted October 24, 2022 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Bazzu85 22 Posted October 25, 2022 Author Posted October 25, 2022 14 hours ago, Luke said: Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! Here's additional info's: no subtitles showed emby server debug log: https://gist.github.com/Bazzu85/b999dc172b0cb61674780eaced630552 as mentioned above using the VTT subtitles extracted on the downloaded folder works. embedded ones works: are these infos enough?
Luke 42237 Posted October 27, 2022 Posted October 27, 2022 When you downloaded it, did you force download the original file? If yes then that is your issue. Select something else and the server will convert the subtitles to something compatible for the app.
Bazzu85 22 Posted October 27, 2022 Author Posted October 27, 2022 8 hours ago, Luke said: When you downloaded it, did you force download the original file? If yes then that is your issue. Select something else and the server will convert the subtitles to something compatible for the app. So the windows store app is not able to play srt subtitles embedded into mkv files? To reply, yes I usually download the original file to preserve all audio and subtitles tracks.
Luke 42237 Posted October 27, 2022 Posted October 27, 2022 17 minutes ago, Bazzu85 said: So the windows store app is not able to play srt subtitles embedded into mkv files? Correct, not at this time.
