happymellon 3 Posted October 22, 2022 Posted October 22, 2022 I was testing an alternative IPTV provider, which appeared to break the Live TV Guide. That no longer shows the list of channels. In an attempt to clean everything up I deleted my TV Sources and Guide Data Sources and let Emby tidy up, but it is still showing a list of programmes, and when I try to add my IPTV provider and their XMLTV Guide, nothing shows up in the guide anymore. I'm assuming that the alternative provider had some dud data and messed up Emby somehow. Is there a Live TV file that I can delete so that Emby can recreate it and remove these programs and channels that do not exist?
happymellon 3 Posted October 22, 2022 Author Posted October 22, 2022 Sorry, I missed a screenshot. The Live TV channel list in settings does not show any channels even though the channel list in Emby does.
happymellon 3 Posted October 23, 2022 Author Posted October 23, 2022 (edited) Interestingly I see this error in the logs when I add the source and guides: 2022-10-23 05:58:51.525 Error Server: Error processing request *** Error Report *** Version: 4.7.8.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-50-generic (buildd@lcy02-amd64-009) (gcc (Ubuntu 9.4.0-1ubuntu1~20.04.1) 9.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #56~20.04. Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 12 Data path: /config Application path: /system System.InvalidOperationException: System.InvalidOperationException: Operation is not valid due to the current state of the object. at Emby.Server.Implementations.Library.LibraryManager.ConvertImageToLocal(BaseItem item, ItemImageInfo image, Int32 imageIndex, CancellationToken cancellationToken) at Emby.Drawing.ImageProcessor.ProcessImage(ImageProcessingOptions options, CancellationToken cancellationToken) at Emby.Api.Images.ImageService.GetImage(ImageRequest request, Int64 itemId, BaseItem item, Boolean isHeadRequest) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() Edited October 23, 2022 by happymellon
Luke 42245 Posted October 24, 2022 Posted October 24, 2022 Hi there, try running the refresh guide scheduled task. Once it finishes the channels should be gone. The server starts this automatically when you make changes to your sources, but it's possible you may have stopped it or restart the server in the middle of it.
