Mookdog 90 Posted October 22, 2022 Posted October 22, 2022 Hey Guys Is there anyway to make a library on emby based off of a genre. Say for instance I want just a library full of the horror genre is it possible ? Mook
Gilgamesh_48 1243 Posted October 22, 2022 Posted October 22, 2022 1 hour ago, Mookdog said: Hey Guys Is there anyway to make a library on emby based off of a genre. Say for instance I want just a library full of the horror genre is it possible ? Mook I "think" the only way to do that would be to copy your horror movies to a new folder and then create a library that contains that folder. However that would not be a good way to access all your horror movies as there are many movies that have multiple genera. It seems the best way to accomplish what you want would be with collections. Just access your movies by genera and go into "horror" and then select all the horror movies and the use the three dot menu to "add to collection" and then create a new "Horror" collection. That seems both easier and faster than the separate folder approach.
Luke 42186 Posted October 22, 2022 Posted October 22, 2022 We plan to add a smart views and playlists feature in future updates that would help with this.
