rbjtech 5345 Posted October 26, 2022 Posted October 26, 2022 and if you literally put the command below into your browser and hit enter (after replacing with your details obviously) - does that work ok ? If yes, then just bookmark it - and run that for a refresh. http://emby.rbjtech.lan:8096/emby/Library/Refresh?api_key=your_api_key If you want it via a clickable icon, then you need to mimic a web browser - which is what curl does. What version of Windows are you using - on I think win 10+ 'curl' is a standard windows utility...
Happy2Play 9814 Posted October 27, 2022 Posted October 27, 2022 Yes what system are you using? But you may need to use the path to where curl is located. As there are dozens of topics for using curl api calls. Similar to here
