Scott D 69 Posted October 21, 2022 Author Posted October 21, 2022 (edited) After reading about others having similar problems (different platforms) that seem to be pointing toward ffmpeg 5.?, if it possible that the problems I am having are related to ffmpeg as well. The first I noticed most of the problems began was on the 19th of May. With the May 17 update having an update to ffmpeg 5.0, seems quite the coincidence. I had been of the belief that the command string being assembled and fed to ffmpeg had changed, causing the problem. But beginning to question the actual ffmpeg. Is it possible to use (install) an older version of ffmpeg as a test? Edited October 21, 2022 by Scott D
Luke 42301 Posted October 21, 2022 Posted October 21, 2022 Quote Return to black screen instead of guide on exiting Live TV Roku remote becomes unresponsive after watching Live TV for 30 minutes or more and then switching to a media file. Requires use of HOME button. By the way these are resolved in the beta which should be up soon.
Scott D 69 Posted October 21, 2022 Author Posted October 21, 2022 4 hours ago, Luke said: By the way these are resolved in the beta which should be up soon. Will this be resolved in a Stable update soon? While I have a Beta server running, it is only for testing purposes.
ebr 16357 Posted October 22, 2022 Posted October 22, 2022 14 hours ago, Scott D said: Will this be resolved in a Stable update soon? Yes. Hopefully, next week.
