paysen 7 Posted October 10, 2023 Posted October 10, 2023 (edited) Hello, I'd like to inquire about a webhook plugin. When I check the "library.deleted" option, it triggers webhook messages successfully when I delete a movie. However, it doesn't trigger correctly when I delete a TV show. What can I do to resolve this issue? Edited October 10, 2023 by paysen
Luke 42255 Posted October 10, 2023 Author Posted October 10, 2023 11 hours ago, paysen said: Hello, I'd like to inquire about a webhook plugin. When I check the "library.deleted" option, it triggers webhook messages successfully when I delete a movie. However, it doesn't trigger correctly when I delete a TV show. What can I do to resolve this issue? Hi there, why do you think it doesn't trigger correctly? How to Report a Problem
paysen 7 Posted October 16, 2023 Posted October 16, 2023 after delete that shows .. webhooks have not sent message to receiver . embyserver (2).txt 1
dual-o 19 Posted February 4, 2024 Posted February 4, 2024 On 9/25/2023 at 9:55 PM, Luke said: Hi, this should be improved in the 4.8 release. Thanks. Thanks to @Lukeand to all of the emby team, webhook is now working very good. I use it for my matrix/element bot. I will write a new tutorial. 1
Luke 42255 Posted February 4, 2024 Author Posted February 4, 2024 4 hours ago, dual-o said: Thanks to @Lukeand to all of the emby team, webhook is now working very good. I use it for my matrix/element bot. I will write a new tutorial. That would be great, thanks !
