80srule 33 Posted October 18, 2022 Posted October 18, 2022 So every time I run a scan or the auto scan runs it goes and then never goes beyond the 87.2%. I have gone in and manually identified tons of stuff thinking ok now it will work. Nope still goes to the same point. I tried looking but I see nothing other then an ffmpeg error but nothing else. https://controlc.com/545c15ee
Luke 42245 Posted October 18, 2022 Posted October 18, 2022 Hi, I don't recognize this domain that you're linking to. Can you please attach the emby server log? Thanks !
80srule 33 Posted October 18, 2022 Author Posted October 18, 2022 that is the server log I couldn't find a past site that would allow me to post the entire thing. I didnt realize I could attach here. Ok so this is the latest log just ran embyserver.txt
Happy2Play 9812 Posted October 18, 2022 Posted October 18, 2022 @Lukeisn't there something wrong with this build with NET 6.0.1? 2022-10-18 04:41:51.959 Info App: Application version: 4.7.8.0 2022-10-18 04:41:51.959 Info App: Emby Command line: /mnt/nvme14n1/ilovemymac/EmbyNET/system/EmbyServer.dll -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe Operating system: Linux version 5.10.103-gentoo-whatbox (root@tangelo.whatbox.ca) (gcc (Gentoo Hardened 11.2.1_p20220115 p4) 11.2.1 20220115, GNU ld (Gentoo 2.37_p1 p2) Framework: .NET 6.0.1 OS/Process: x64/x64 Runtime: mnt/nvme14n1/ilovemymac/dotnet/shared/Microsoft.NETCore.App/6.0.1/System.Private.CoreLib.dll Processor count: 256
rockon76 0 Posted October 18, 2022 Posted October 18, 2022 How do you change builds without wiping your entire library?
80srule 33 Posted October 18, 2022 Author Posted October 18, 2022 Just now, rockon76 said: How do you change builds without wiping your entire library? Yea my library is huge. I don’t want to start over lol.
Happy2Play 9812 Posted October 18, 2022 Posted October 18, 2022 (edited) @80srule But Emby has advanced beyond NET 6.0.1 but believe it is platform prevalent. Windows is on NET 6.0.9. But I am only guessing here, and it may be irrelevant. But know there Linux issues on 6.0.2. Other Linux logs show 6.0.8. Did you compile your own build? But nothing really stands out in that log beside numbers. Edited October 18, 2022 by Happy2Play
80srule 33 Posted October 18, 2022 Author Posted October 18, 2022 2 minutes ago, Happy2Play said: @80srule But Emby has advanced beyond NET 6.0.1 but believe it is platform prevalent. Windows is on NET 6.0.9. But I am only guessing here, and it may be irrelevant. But know there Linux issues on 6.0.2. Other Linux logs show 6.0.8. Did you compile your own build? But nothing really stands out in that log beside numbers. I didn’t do anything I just followed the directions to install it and that was it. Are use a seat box server, and they have the directions all laid out and I just followed those. https://whatbox.ca/wiki/Emby
Happy2Play 9812 Posted October 18, 2022 Posted October 18, 2022 @80srule At the same time I don't see those instructions keeping up with Emby changes. You may have the updated server but stuck in time with NET core. But devs will have to comment further as this is all speculation on my part as a non Linux user.
Luke 42245 Posted October 18, 2022 Posted October 18, 2022 Who is packaging this for Gentoo? I would suggest using our Docker container instead so that you're getting something that is officially put together by us. Then all of the required components will be self-contained.
Happy2Play 9812 Posted October 18, 2022 Posted October 18, 2022 @Luke Seedbox instructions https://whatbox.ca/wiki/Emby, I would assume every update their wiki would outdated.
80srule 33 Posted October 18, 2022 Author Posted October 18, 2022 7 minutes ago, Luke said: Who is packaging this for Gentoo? I would suggest using our Docker container instead so that you're getting something that is officially put together by us. Then all of the required components will be self-contained. So is this possible without wiping my entire library?
Happy2Play 9812 Posted October 18, 2022 Posted October 18, 2022 9 minutes ago, 80srule said: So is this possible without wiping my entire library? Does your box allow Docker containers? If so you would want to copy the entire "/mnt/nvme14n1/ilovemymac/EmbyNET/programdata" from one to the other. But for current install you would need to manually update NET Core Runtime per step 1. But @Lukewould have to confirm version number. At the same time have no idea what the url would be for that version
80srule 33 Posted October 18, 2022 Author Posted October 18, 2022 I don't see why not. I never tried but I assume im open to install whatever I need
Luke 42245 Posted October 19, 2022 Posted October 19, 2022 I personally would go the Docker route. Even if you update the .net runtime with this gentoo package, I can also see that it's missing other required components that we embed. Let us know how you get on. Thanks.
80srule 33 Posted October 19, 2022 Author Posted October 19, 2022 I usually ssh into the server via the command line on the computer. So how would I install docker
Luke 42245 Posted October 19, 2022 Posted October 19, 2022 3 hours ago, 80srule said: I usually ssh into the server via the command line on the computer. So how would I install docker Please take a look at our install instructions and let us know if this helps: https://emby.media/docker-server.html Thanks.
80srule 33 Posted October 20, 2022 Author Posted October 20, 2022 We do not provide Docker at this time and Docker containers will not work. There are currently many projects that expect access to virtualized containers (and/or root access) to run; we are investigating ways to support them better. For now, Emby can only be run with the instructions we provide, which install .NET to your home directory and then run Emby's latest provided release with that version of .NET. I've updated our instructions to use 6.0.10 which is the latest version of the .NET Runtime provided by Microsoft. This was there response
Happy2Play 9812 Posted October 20, 2022 Posted October 20, 2022 @80srule Not sure if that will create issues as Emby is not currently developed with that version. But I guess you can test. Other issue will be this setup is not using Emby customized ffmpeg/ffprobe ffprobe version 4.4.3 Copyright (c) 2007-2022 the FFmpeg developers vs ffprobe version 5.0.0-emby_2022_05_27-u1 Copyright (c) 2007-2022 the FFmpeg developers and softworkz for Emby LLC 2 minutes ago, Luke said: Hi, who said that? I would assume the provider "whatbox".
80srule 33 Posted October 20, 2022 Author Posted October 20, 2022 5 minutes ago, Luke said: Hi, who said that? My server provider, Whatbox
80srule 33 Posted October 20, 2022 Author Posted October 20, 2022 3 minutes ago, Happy2Play said: @80srule Not sure if that will create issues as Emby is not currently developed with that version. But I guess you can test. Other issue will be this setup is not using Emby customized ffmpeg/ffprobe ffprobe version 4.4.3 Copyright (c) 2007-2022 the FFmpeg developers vs ffprobe version 5.0.0-emby_2022_05_27-u1 Copyright (c) 2007-2022 the FFmpeg developers and softworkz for Emby LLC I would assume the provider "whatbox". How would you update that?
Happy2Play 9812 Posted October 20, 2022 Posted October 20, 2022 9 minutes ago, 80srule said: How would you update that? Sorry not a Linux user. But comparing another log here you can see differences. You can see it is using NET 6.0.8. But would guess a config file somewhere pointing to Emby. FfmpegManager: FFMpeg: /mnt/nvme14n1/ilovemymac/EmbyNET/bin/ffmpeg FfmpegManager: FFProbe: /mnt/nvme14n1/ilovemymac/EmbyNET/bin/ffprobe FfmpegManager: FFDetect: /mnt/nvme14n1/ilovemymac/EmbyNET/bin/ffdetect
80srule 33 Posted October 20, 2022 Author Posted October 20, 2022 I updated the net runtime to the latest from Microsoft. Although I wish that we didn’t have to use stuff from Microsoft. Now I just need to figure out how to update the FFmpg.
80srule 33 Posted October 20, 2022 Author Posted October 20, 2022 27 minutes ago, Happy2Play said: Sorry not a Linux user. But comparing another log here you can see differences. You can see it is using NET 6.0.8. But would guess a config file somewhere pointing to Emby. FfmpegManager: FFMpeg: /mnt/nvme14n1/ilovemymac/EmbyNET/bin/ffmpeg FfmpegManager: FFProbe: /mnt/nvme14n1/ilovemymac/EmbyNET/bin/ffprobe FfmpegManager: FFDetect: /mnt/nvme14n1/ilovemymac/EmbyNET/bin/ffdetect Server company says Emby's release files don't provide ffmpeg or ffprobe, so our instructions use the server's installed version of ffmpeg/ffprobe. If you're receiving an error specific to our versions of ffmpeg/ffprobe, please let us know the error messages and log output.
