fredflix 31 Posted October 18, 2022 Posted October 18, 2022 (edited) My container became unresponsive to the point where I couldn't even kill it (not sure what caused it). A server reboot let me delete and relaunch the container. However, while the container is still running, Emby isn't. Something to do with sqlite? I'm not sure. The log below just keeps looping over and over. Info Main: Emby Command line: /app/emby/EmbyServer.dll -programdata /config -ffdetect /app/emby/ffdetect -ffmpeg /app/emby/ffmpeg -ffprobe /app/emby/ffprobe -restartexitcode 3 Operating system: Linux version 5.10.0-18-amd64 (debian-kernel@lists.debian.org) (gcc-10 (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: app/emby/System.Private.CoreLib.dll Processor count: 12 Data path: /config Application path: /app/emby Info Main: Logs path: /config/logs Info Main: Cache path: /config/cache Info Main: Internal metadata path: /config/metadata Info Main: Transcoding temporary files path: /config/transcoding-temp Info App: Application version: 4.7.8.0 Info App: Loading assemblies Info App: File /config/plugins/Fanart.dll has version 1.0.13.0 Info App: File /app/emby/plugins/Fanart.dll has version 1.0.13.0 Info App: File /config/plugins/MovieDb.dll has version 1.6.2.0 Info App: File /app/emby/plugins/MovieDb.dll has version 1.6.2.0 Info App: File /config/plugins/EmbyGuideData.dll has version 1.0.7.0 Info App: File /app/emby/plugins/EmbyGuideData.dll has version 1.0.7.0 Info App: File /config/plugins/Tvdb.dll has version 1.3.2.0 Info App: File /app/emby/plugins/Tvdb.dll has version 1.3.1.0 Info App: File /config/plugins/OMDb.dll has version 1.0.18.0 Info App: File /app/emby/plugins/OMDb.dll has version 1.0.18.0 Info App: File /config/plugins/StudioImages.dll has version 1.0.3.0 Info App: File /app/emby/plugins/StudioImages.dll has version 1.0.3.0 Info App: File /config/plugins/Emby.PortMapper.dll has version 1.1.8.0 Info App: File /app/emby/plugins/Emby.PortMapper.dll has version 1.1.8.0 Info App: Loading Fanart, Version=1.0.13.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Fanart.dll Info App: Loading MovieDb, Version=1.6.2.0, Culture=neutral, PublicKeyToken=null from /config/plugins/MovieDb.dll Info App: Loading CoverArt, Version=4.1.18.0, Culture=neutral, PublicKeyToken=null from /config/plugins/CoverArt.dll Info App: Loading MediaBrowser.Plugins.Anime, Version=1.5.3.0, Culture=neutral, PublicKeyToken=null from /config/plugins/MediaBrowser.Plugins.Anime.dll Info App: Loading EmbyGuideData, Version=1.0.7.0, Culture=neutral, PublicKeyToken=null from /config/plugins/EmbyGuideData.dll Info App: Loading ThemeSongs, Version=1.6.6.7, Culture=neutral, PublicKeyToken=null from /config/plugins/themesongs.dll Info App: Loading Tvdb, Version=1.3.2.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Tvdb.dll Info App: Loading OMDb, Version=1.0.18.0, Culture=neutral, PublicKeyToken=null from /config/plugins/OMDb.dll Info App: Loading StudioImages, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null from /config/plugins/StudioImages.dll Info App: Loading InfuseSync, Version=1.4.2.0, Culture=neutral, PublicKeyToken=null from /config/plugins/InfuseSync.dll Info App: Loading MediaBrowser.Plugins.GotifyNotifications, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /config/plugins/MediaBrowser.Plugins.GotifyNotifications.dll Info App: Loading Emby.DiagnosticsPlugin, Version=4.7.0.60, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.DiagnosticsPlugin.dll Info App: Loading Emby.PortMapper, Version=1.1.8.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.PortMapper.dll Info App: Loading Emby.Api, Version=4.7.8.0, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Web, Version=4.7.8.0, Culture=neutral, PublicKeyToken=null Info App: Loading MediaBrowser.Model, Version=4.7.8.0, Culture=neutral, PublicKeyToken=null Info App: Loading MediaBrowser.Common, Version=4.7.8.0, Culture=neutral, PublicKeyToken=null Info App: Loading MediaBrowser.Controller, Version=4.7.8.0, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Providers, Version=4.7.8.0, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Photos, Version=4.7.8.0, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Server.Implementations, Version=4.7.8.0, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.LiveTV, Version=4.7.8.0, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.ActivityLog, Version=4.7.8.0, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Server.MediaEncoding, Version=4.7.8.0, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.LocalMetadata, Version=4.7.8.0, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Notifications, Version=4.7.8.0, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Codecs.Dxva, Version=4.7.8.0, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Codecs, Version=4.7.8.0, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Server.Connect, Version=4.7.8.0, Culture=neutral, PublicKeyToken=null Info App: Loading Emby.Server.Sync, Version=4.7.8.0, Culture=neutral, PublicKeyToken=null Info App: Loading EmbyServer, Version=4.7.8.0, Culture=neutral, PublicKeyToken=null Info SqliteUserRepository: Sqlite version: 3.39.2 Info SqliteUserRepository: Sqlite compiler options: ATOMIC_INTRINSICS=1,COMPILER=gcc-10.3.0,DEFAULT_AUTOVACUUM,DEFAULT_CACHE_SIZE=-2000,DEFAULT_FILE_FORMAT=4,DEFAULT_JOURNAL_SIZE_LIMIT=-1,DEFAULT_MMAP_SIZE=0,DEFAULT_PAGE_SIZE=4096,DEFAULT_PCACHE_INITSZ=20,DEFAULT_RECURSIVE_TRIGGERS,DEFAULT_SECTOR_SIZE=4096,DEFAULT_SYNCHRONOUS=2,DEFAULT_WAL_AUTOCHECKPOINT=1000,DEFAULT_WAL_SYNCHRONOUS=2,DEFAULT_WORKER_THREADS=0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS4,ENABLE_FTS5,ENABLE_GEOPOLY,ENABLE_MATH_FUNCTIONS,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MALLOC_SOFT_LIMIT=1024,MAX_ATTACHED=10,MAX_COLUMN=2000,MAX_COMPOUND_SELECT=500,MAX_DEFAULT_PAGE_SIZE=8192,MAX_EXPR_DEPTH=1000,MAX_FUNCTION_ARG=127,MAX_LENGTH=1000000000,MAX_LIKE_PATTERN_LENGTH=50000,MAX_MMAP_SIZE=0x7fff0000,MAX_PAGE_COUNT=1073741823,MAX_PAGE_SIZE=65536,MAX_SCHEMA_RETRY=25,MAX_SQL_LENGTH=1000000000,MAX_TRIGGER_DEPTH=1000,MAX_VARIABLE_NUMBER=250000,MAX_VDBE_OP=250000000,MAX_WORKER_THREADS=8,MUTEX_PTHREADS,OMIT_LOOKASIDE,SECURE_DELETE,SYSTEM_MALLOC,TEMP_STORE=1,THREADSAFE=1 Info SqliteUserRepository: Opening sqlite connection to /config/data/users.db Info SqliteUserRepository: Default journal_mode for /config/data/users.db is wal Info ActivityRepository: Opening sqlite connection to /config/data/activitylog.db Info ActivityRepository: Default journal_mode for /config/data/activitylog.db is wal Info SqliteDisplayPreferencesRepository: Opening sqlite connection to /config/data/displaypreferences.db Info SqliteDisplayPreferencesRepository: Default journal_mode for /config/data/displaypreferences.db is wal Info App: Adding HttpListener prefix http://+:8096/ Info NetworkManager: Detecting local network addresses Info NetworkManager: networkInterface: Ethernet eth0, Speed: 10000000000, Description: eth0 Info NetworkManager: GatewayAddresses: 172.30.110.1 Info NetworkManager: UnicastAddresses: 172.30.110.3 Info NetworkManager: networkInterface: Ethernet eth1, Speed: 10000000000, Description: eth1 Info NetworkManager: GatewayAddresses: Info NetworkManager: UnicastAddresses: 172.30.105.4 Info NetworkManager: networkInterface: Loopback lo, Speed: -1, Description: lo Info NetworkManager: GatewayAddresses: Info NetworkManager: UnicastAddresses: 127.0.0.1 Info NetworkManager: Detected local ip addresses: 172.30.110.3, 172.30.105.4, 127.0.0.1 Info AuthenticationRepository: Opening sqlite connection to /config/data/authentication.db Info AuthenticationRepository: Default journal_mode for /config/data/authentication.db is wal Info SqliteItemRepository: Opening sqlite connection to /config/data/library.db Error Main: Error in appHost.Init *** Error Report *** Version: 4.7.8.0 Command line: /app/emby/EmbyServer.dll -programdata /config -ffdetect /app/emby/ffdetect -ffmpeg /app/emby/ffmpeg -ffprobe /app/emby/ffprobe -restartexitcode 3 Operating system: Linux version 5.10.0-18-amd64 (debian-kernel@lists.debian.org) (gcc-10 (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: app/emby/System.Private.CoreLib.dll Processor count: 12 Data path: /config Application path: /app/emby SQLitePCL.pretty.SQLiteException: Busy: database is locked - PRAGMA journal_mode SQLitePCL.pretty.SQLiteException: Exception of type 'SQLitePCL.pretty.SQLiteException' was thrown. at SQLitePCL.pretty.SQLiteDatabaseConnection.PrepareStatement(String sql, String& tail) at SQLitePCL.pretty.DatabaseConnection.PrepareStatement(IDatabaseConnection This, String sql) at Emby.Sqlite.BaseSqliteRepository.CreateConnection(Boolean isReadOnly) at Emby.Server.Implementations.Data.SqliteItemRepository.Initialize(SqliteUserDataRepository userDataRepo, IUserManager userManager) at Emby.Server.Implementations.ApplicationHost.InitDatabases() at Emby.Server.Implementations.ApplicationHost.Init() at EmbyServer.HostedService.StartAsync(CancellationToken cancellationToken) Source: SQLitePCL.pretty TargetSite: SQLitePCL.pretty.IStatement PrepareStatement(System.String, System.String ByRef) Info Main: Shutdown complete Info Main: Application path: /app/emby/EmbyServer.dll Edited October 18, 2022 by fredflix
fredflix 31 Posted October 18, 2022 Author Posted October 18, 2022 Nevermind, after another server reboot, deleting the shm and wal files in /data, it all went back to normal
Solution Luke 42245 Posted October 18, 2022 Solution Posted October 18, 2022 Thanks for following up. If this happens again and persists, then this should help get you squared away: https://support.emby.media/support/solutions/articles/44002210894-corrupt-database 1
fredflix 31 Posted October 18, 2022 Author Posted October 18, 2022 1 hour ago, Luke said: Thanks for following up. If this happens again and persists, then this should help get you squared away: https://support.emby.media/support/solutions/articles/44002210894-corrupt-database This is great. That's basically what I did, without knowing the solution was actually in the FAQ as it seemed like an isolated incident. Thanks Luke 1
