spon 26 Posted October 17, 2022 Posted October 17, 2022 Hi everyone. I've attached a log file for a test file in which the server is transcoding rather than Direct Play, which is causing issues with the HDR. Can someone take a look and let me know what is causing the transcoding? I've read it could be something with the audio format or possible compression issues but the log file is a little confusing. Thank you! ffmpeg-transcode-45592e29-9de4-49f4-b6cd-5129b664ae0c_1.txt
Luke 42186 Posted October 17, 2022 Posted October 17, 2022 Hi there, did you explore the stats feature in the video player to learn why it was transcoding?
spon 26 Posted October 17, 2022 Author Posted October 17, 2022 hey @luke. I did check the video player (advanced stats for nerds) and can see that it is transcoding, but I couldn't tell why. After revisiting, it looks like there are two issues. Initially, there was no explicit reason shown, but after the Transcoding progress (1.2%) it said "burning in subtitles". I then remember that non-srt subtitles are an issue with HDR so I disabled the subtitles and tried again. This time it said Transcoding reason: Direct Play error.
Luke 42186 Posted October 17, 2022 Posted October 17, 2022 OK. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
spon 26 Posted October 17, 2022 Author Posted October 17, 2022 (edited) 26 minutes ago, Luke said: OK. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks. Sure, but just to be clear, the emby app that I'm using on my Shield Pro (via the google play store) is different than the sideloaded version? edited: I'm using Emby Server on a dedicated PC, Shield Pro (latest version) w/ Emby app, Yamaha receiver (HDR & UHD compatible) to a Samsung S95B Edit 2: I should have mentioned up front that I downloaded a HDR reference video (TS file) and it played beautifully in Emby with Direct Play. Edited October 17, 2022 by spon
Luke 42186 Posted October 18, 2022 Posted October 18, 2022 21 hours ago, spon said: Sure, but just to be clear, the emby app that I'm using on my Shield Pro (via the google play store) is different than the sideloaded version? edited: I'm using Emby Server on a dedicated PC, Shield Pro (latest version) w/ Emby app, Yamaha receiver (HDR & UHD compatible) to a Samsung S95B Edit 2: I should have mentioned up front that I downloaded a HDR reference video (TS file) and it played beautifully in Emby with Direct Play. @spon Hi, yes, the sideloaded app is ahead in terms of video player updates. Can you try it out and let us know how that compares? Thanks !
spon 26 Posted October 19, 2022 Author Posted October 19, 2022 @Luke the sideload app played all the files fine so it looks like the issue is resolved in the latest version of the video player. All good. Thanks man! 1
