EODCrafter 181 Posted February 29, 2024 Author Posted February 29, 2024 (edited) Enough with the TDS please. Bill Edited February 29, 2024 by EODCrafter 1
Locutus64 125 Posted February 29, 2024 Posted February 29, 2024 (edited) You didn't even remotely help your cause, but you knew that when you posted that. It says nothing about not being able to download for personal use. It's about using the content for one's personal financial use aka selling the content to others or charging others to view the downloaded content. But enough, blocked for being a Trump supporter. Edited February 29, 2024 by Locutus64
EODCrafter 181 Posted February 29, 2024 Author Posted February 29, 2024 (edited) In response to @ebr, I did nothing illegal, Emby is for Personal use. Edited February 29, 2024 by EODCrafter 1
ebr 16346 Posted February 29, 2024 Posted February 29, 2024 7 hours ago, EODCrafter said: I did nothing illegal, Correct, you have done nothing wrong here and I did not mean to imply that. My ask was for a legal provider of "catch up" TV that we would be able to integrate with (since that is the title of this topic). To my knowledge, all such providers are violating the bill you cite OR are proprietary to their own systems such that we wouldn't be able to integrate with them. 1
EODCrafter 181 Posted February 29, 2024 Author Posted February 29, 2024 (edited) All I need is to go backwards in the tv guide as @Lukesaid Thanks! Edited February 29, 2024 by EODCrafter 1 1
EladBar 4 Posted September 22, 2024 Posted September 22, 2024 Any update about that feature? It would be great to have the ability to play a stream was live few days ago in case supported by the provider (LiveTV, NVR systems, etc...) thanks
Luke 42260 Posted September 24, 2024 Posted September 24, 2024 On 9/22/2024 at 4:44 AM, EladBar said: Any update about that feature? It would be great to have the ability to play a stream was live few days ago in case supported by the provider (LiveTV, NVR systems, etc...) thanks Hi, no update yet, but it's possible for future updates. Thanks.
monistra 1 Posted February 2, 2025 Posted February 2, 2025 this would be a major feature update if implemented.
Ratatouille 14 Posted June 1, 2025 Posted June 1, 2025 Wondering if it will ever happen, maybe we have to go back to kodi!
Squash_Konrad 0 Posted October 16, 2025 Posted October 16, 2025 On 10/17/2022 at 8:36 PM, Luke said: Hi, it means we'd have to keep older guide data around. In theory it should be possible. Hi, it is almost 3 years.... When you are planing to implement this?
Luke 42260 Posted October 16, 2025 Posted October 16, 2025 3 hours ago, Squash_Konrad said: Hi, it is almost 3 years.... When you are planing to implement this? You could do this now with the new webstreams plugin.
Luke 42260 Posted October 16, 2025 Posted October 16, 2025 Well not integration with the guide but just from the standpoint of importing vod
