wepache 3 Posted October 17, 2022 Posted October 17, 2022 (edited) I have HDHomeRun setup in my Emby server. I have MPV enabled. I need it enabled or else my M3U links won’t work. I am using an Apple TV. The HDHomeRun channels won’t auto start. A single frame loads up, and the loading wheel spins indefinite unless I press down on my remote and scroll around. i attached a 35 second video showing exactly what I am talking about. Is this a known issue? IMG_0512.MOV Edited October 17, 2022 by wepache New info
jmanship 2 Posted October 17, 2022 Posted October 17, 2022 I’ve got the same issue. I turn off “enable mpv” and it will at least load. It still freezes after a few min. When using live TV HD Homerun Flex 4k Synology 920+ playing on Apple TV
Luke 42240 Posted October 17, 2022 Posted October 17, 2022 Hi, we'll take a look at it. Thanks for reporting.
wepache 3 Posted October 18, 2022 Author Posted October 18, 2022 3 hours ago, jmanship said: I’ve got the same issue. I turn off “enable mpv” and it will at least load. It still freezes after a few min. When using live TV HD Homerun Flex 4k Synology 920+ playing on Apple TV Yes. This is also the case with me too. The issue is that I need MPV on or else my other M3U links won’t work in Live TV.
patrice jean 0 Posted October 19, 2022 Posted October 19, 2022 Similar problem with the latest Emby app on Apple TV and TVHEADEND plug-in trying to stream UK HD channels Funnily with 1.6.3 I do not have this issue on an Apple TV which was not updated with those on latest version it is a fail
jmanship 2 Posted October 19, 2022 Posted October 19, 2022 Yeah. I've got two Apple TV's the problem won't duplicate on the one running 1.5.9. on 1.6.4 it is pretty consistent.
patrice jean 0 Posted October 21, 2022 Posted October 21, 2022 4 hours ago, Luke said: We're looking into this. Thanks guys. Ok thanks fingers crossed
Mulie 0 Posted November 5, 2022 Posted November 5, 2022 Anything new on this issue? Happening on my AppleTV for vod. Freezes on first frame of any video we play.
EddyMerkxs 17 Posted November 5, 2022 Posted November 5, 2022 It freezes for me but after it buffers a sec you can skip forward and it’ll play.
Luke 42240 Posted November 6, 2022 Posted November 6, 2022 We're hoping to have a fix out soon. Thanks guys.
