bill_w 1 Posted October 17, 2022 Posted October 17, 2022 When editing metadata for a movie, Emby may show an IMDB value to three decimals, like 6.615. If you then edit another field and try to save, it will pop up an error saying that it doesn't accept three decimals and suggesting that you use 6.6 or 6.7 instead. If it is capable of storing three decimals obtained from IMDB, it probably ought to accept the same precision for input values. Obviously, this is a minor problem. I'm just reporting it in case someone else hasn't done so already.
Happy2Play 9812 Posted October 17, 2022 Posted October 17, 2022 Yes there are a few topics on this as I believe it is a TMDB issue. I know @Lukewas looking into it.
Luke 42245 Posted October 17, 2022 Posted October 17, 2022 Hi, yes this is being looked into. Thanks. 1
