joshhuggins 22 Posted October 16, 2022 Posted October 16, 2022 It would be nice if we could resize Emby Theater from the top edge of the app. I use it on my desktop a lot on a multi monitor setup and depending on my current work project, I move it between my different monitors which have different resolutions. When doing so, often the bottom edge gets lost off the bottom edge of the screen so I can't resize the window vertically because the top can't be used to resize the app. I usually have to drag it back to my largest resolution display, Maximize and Restore the window, resize it down to it's minimum, then drag it to the desired monitor and then I can maximize it again. 2
Luke 42246 Posted October 16, 2022 Posted October 16, 2022 Hi, yes it makes sense. Thanks for the feedback. 1
