oceanclub 12 Posted October 16, 2022 Posted October 16, 2022 I recently got a wireless speaker the Audio Pro C5 (https://www.audiopro.com/en/product/addon-c5/#black). This has the ability to be connected to your network (either wireless or Ethernet) and stream music from a DLNA network share. However I've tried this with both the Audio Pro official Android app and with the MediaMonkey Pro Android app and it's a fairly unfriendly experience. Each time, you have to drill down into the GUI from the network to your PC to the music folder, etc, etc, and when you get to the list of music it takes about a minute to update. And you can't cue up music either. So I noticed that the speaker is visible to Emby on my PC and on my phone (see screenshot). However I select it and press Play for music nothing happens. I imagine this is based on how Emby has its own view of the music library which is not accessible by the speaker as a DLNA share. However I would love if Emby could add this functionality - is it possible and are there any plans to? (Oh and I know I _could_ use Bluetooth for all this but obviously would prefer over wifi/ethernet for quality purposes.)
Luke 42186 Posted October 18, 2022 Posted October 18, 2022 Hi, what did you press play on? Can you please provide an example? How to Report a Problem Thanks.
oceanclub 12 Posted October 25, 2022 Author Posted October 25, 2022 Hi there, In this instance, I went into my Music collection after I had selected the speaker, then clicked Play on the album. I've uploaded the relevant log file here. embyserver.txt
Luke 42186 Posted October 25, 2022 Posted October 25, 2022 That's strange. Does your server dashboard display a local lan address?
oceanclub 12 Posted November 2, 2022 Author Posted November 2, 2022 On 25/10/2022 at 20:52, Luke said: That's strange. Does your server dashboard display a local lan address? Do you know where I would see that? I see a "Remote (WAN) access:" value?
Luke 42186 Posted November 2, 2022 Posted November 2, 2022 1 hour ago, oceanclub said: Do you know where I would see that? I see a "Remote (WAN) access:" value? Is there a LAN address value right above that?
oceanclub 12 Posted November 2, 2022 Author Posted November 2, 2022 15 minutes ago, Luke said: Is there a LAN address value right above that? No; see attached for what I see, unless this value is elsewhere.
Luke 42186 Posted November 2, 2022 Posted November 2, 2022 OK, that's the reason for the problem. Is there anything odd about your local network setup?
oceanclub 12 Posted November 2, 2022 Author Posted November 2, 2022 (edited) 25 minutes ago, Luke said: OK, that's the reason for the problem. Is there anything odd about your local network setup? Not that I know of but can you point me at any advice/troubleshooters/etc? To be more concise; how do I get Emby to display my LAN address? Edited November 2, 2022 by oceanclub
Luke 42186 Posted November 15, 2022 Posted November 15, 2022 On 11/2/2022 at 7:08 PM, oceanclub said: Not that I know of but can you point me at any advice/troubleshooters/etc? To be more concise; how do I get Emby to display my LAN address? @oceanclub can you please attach an emby server log from starting up the server? Hopefully that will tell us what local LAN ip addresses were detected. Thanks.
oceanclub 12 Posted November 22, 2022 Author Posted November 22, 2022 Hi @Luke here you go. embyserver.txt
Luke 42186 Posted December 14, 2022 Posted December 14, 2022 @oceanclub are you still running into this?
oceanclub 12 Posted December 16, 2022 Author Posted December 16, 2022 On 14/12/2022 at 19:47, Luke said: @oceanclub are you still running into this? Hi Luke, yes I am - still nothing plays as in my original post.
Solution oceanclub 12 Posted January 28, 2023 Author Solution Posted January 28, 2023 (edited) Well, I managed to fix this! I was actually looking into why my computer was slow in shutting down, and at the point running a report found that the following services were not running (and giving an error when started): * Peer Name Resolution Protocol * Peer Networking Grouping The following solutions fixed this: https://www.majorgeeks.com/content/page/windows_could_not_the_start_peer_networking_grouping_service_on_local_computer.html https://answers.microsoft.com/en-us/windows/forum/all/windows-could-not-start-the-peer-name-resolution/c50b8931-7c59-e011-8dfc-68b599b31bf5 In summary: 1. In C:\ProgramData\Microsoft\Crypto\RSA, rename the folder MachineKeys to MachineKeys.old, then create a new folder MachineKeys, then right-click, Properties > Security, select Everyone, set to Full Control. 2. In C:\Windows\ServiceProfiles\LocalService\AppData\Roaming\PeerNetworking, rename idstore.sst to idstore.sst.OLD, then reboot. I figured this had something to do with my networking issues, so tried Emby after this, and now I can play music to my wifi speaker (Audio Pro C5A). Now I would just love it if I could play to multiple speakers simultaneously! P. Edited January 28, 2023 by oceanclub 1
