arrbee99 1836 Posted October 15, 2022 Posted October 15, 2022 I've got things like this transparent and blurry - but things like this aren't - I though this would work - /* Try to make Filter and three dots dropdowns transparent and blurry */ div.formDialogContent.emby-scroller.scrollY.overflowYScroll.scrollFrameY {backdrop-filter: saturate(1.8) blur(1.5em);} div.formDialogContent.emby-scroller.scrollY.overflowYScroll.scrollFrameY {background-color: rgba(0, 0, 0, 0.3) !important;} /*div.formDialogContent.emby-scroller.scrollY.overflowYScroll.scrollFrameY {background-color: red !important;}*/ but of course it doesn't. I mean the third line to make it red works fine, but the proper one ( the line above doesn't) and don't get why. Unless the whole thing is rubbish.
Happy2Play 9811 Posted October 15, 2022 Posted October 15, 2022 (edited) Just need to go up a couple levels and you would have seen it applied via .dialog.@arrbee99 something like this /* Try to make Filter and three dots dropdowns transparent and blurry */ div.focuscontainer.dialog {backdrop-filter: saturate(1.8) blur(1.5em);} div.focuscontainer.dialog {background-color: rgba(0, 0, 0, 0.3);} If you want different color change the rgba. Edited October 15, 2022 by Happy2Play
arrbee99 1836 Posted October 15, 2022 Author Posted October 15, 2022 I'm getting better, I got the div bit correct... Thanks again for putting up with me
