pwhodges 2039 Posted October 20, 2022 Posted October 20, 2022 (edited) There is a patch to remove the driver limitation: https://github.com/keylase/nvidia-patch/blob/master/win/README.md I don't know about Emby's use of multiple cards (I suspect it can't, but it's planned). Paul Edited October 20, 2022 by pwhodges
nightknight 35 Posted October 20, 2022 Author Posted October 20, 2022 (edited) How can i tell if emby transcoding is being limited by the gpu driver / does each client transcode count? does that mean the second transcode would be all on the cpu? Edited October 20, 2022 by nightknight
Luke 42287 Posted October 20, 2022 Posted October 20, 2022 7 hours ago, nightknight said: How can i tell if emby transcoding is being limited by the gpu driver / does each client transcode count? does that mean the second transcode would be all on the cpu? Hi have you explored the stats feature in the video player during playback? 1
nightknight 35 Posted October 21, 2022 Author Posted October 21, 2022 (edited) I have been having alot of issues with direct play remotely/lan. On both the lan and the remote the direct play takes a while to load. from remote sometimes more than 45 seconds to load an episode. ive confirmed its not a bandwidth issue. if a video starts in transcode the stream works perfect. not sure what to do. have any ideas? the direct play stream was only 1mbps. i dont understand why the delay. It not all direct play streams either. some work fine Edited October 21, 2022 by nightknight
Luke 42287 Posted October 21, 2022 Posted October 21, 2022 4 hours ago, nightknight said: I have been having alot of issues with direct play remotely/lan. On both the lan and the remote the direct play takes a while to load. from remote sometimes more than 45 seconds to load an episode. ive confirmed its not a bandwidth issue. if a video starts in transcode the stream works perfect. not sure what to do. have any ideas? the direct play stream was only 1mbps. i dont understand why the delay. It not all direct play streams either. some work fine How have you confirmed it's not a bandwidth issue? There could be isp throttling occurring on either side of the connection.
nightknight 35 Posted October 21, 2022 Author Posted October 21, 2022 (edited) nope no throttles.i can get my crappy almost 40mbps upload speed between my vpn server "tcp" and the client "depending on encryption strength". The problem persists regardless of 600mb movie/9 gb movie. The largest movie in my library "9gb" loads without problems. But a lot of 600mb movies don't load quick they take forever to start. Edited October 21, 2022 by nightknight
Luke 42287 Posted October 21, 2022 Posted October 21, 2022 30 minutes ago, nightknight said: nope no throttles. How did you confirm this? A lot of ISP's are doing this now.
Luke 42287 Posted October 21, 2022 Posted October 21, 2022 2 minutes ago, nightknight said: By transferring a file using what?
Luke 42287 Posted October 21, 2022 Posted October 21, 2022 8 minutes ago, nightknight said: The internet OK that's not a very detailed answer, but unless the test was on the same port that you connect to the server with, then the results are not necessarily applicable. Was it? I'm guessing not.
nightknight 35 Posted October 21, 2022 Author Posted October 21, 2022 Yea i connect to the server through an encrypted tunnel. The only port is my vpn server. And its not throttled. I use it every day for file transfers.
nightknight 35 Posted October 21, 2022 Author Posted October 21, 2022 (edited) I tried this from 4 different android phones. 2 were on different sides of the planet. The direct play stream is only 1mbps and it still takes forever to load. Other wise I have no problem playing a 6mbps direct play stream from 4 phones at a time. Other than the load time for some videos. transcodig at those bitrates/above have no issue starting. Edited October 21, 2022 by nightknight
ebr 16354 Posted October 21, 2022 Posted October 21, 2022 1 hour ago, nightknight said: The direct play stream is only 1mbps and it still takes forever to load. Other wise I have no problem playing a 6mbps direct play stream from 4 phones at a time. Other than the load time for some videos What is different or unique about the items with this issue? This sounds to me like the player is having to bring the whole file down before it can start playback so it could be some sort of structure issue with the file itself.
nightknight 35 Posted October 21, 2022 Author Posted October 21, 2022 my files are on local hdds. Most of them downloaded with yt dlp. I just cant explain why some videos do/dont have load issues. What kind of struture problems can cause this?
ebr 16354 Posted October 22, 2022 Posted October 22, 2022 In what format/container are the files? If you run mediainfo on one that works and one that doesn't, what is different?
nightknight 35 Posted October 22, 2022 Author Posted October 22, 2022 (edited) I"ll try this. But stupid question, how do I run mediainfo? Not sure what mediainfo is Edited October 22, 2022 by nightknight
ebr 16354 Posted October 23, 2022 Posted October 23, 2022 On 10/22/2022 at 9:05 AM, nightknight said: But stupid question, how do I run mediainfo? Not sure what mediainfo is It is a program that will show you the internals of the file. Google it...
Tenguman 4 Posted October 24, 2022 Posted October 24, 2022 On 10/21/2022 at 4:03 AM, nightknight said: I have been having alot of issues with direct play remotely/lan. On both the lan and the remote the direct play takes a while to load. from remote sometimes more than 45 seconds to load an episode. ive confirmed its not a bandwidth issue. if a video starts in transcode the stream works perfect. not sure what to do. have any ideas? the direct play stream was only 1mbps. i dont understand why the delay. It not all direct play streams either. some work fine lowing resolution is the first step for transcoding ¿Do you observe how change the resolution in "Statistic for nerds"?
