Luke 42237 Posted February 17, 2023 Posted February 17, 2023 27 minutes ago, jbl77 said: Got the exact same issue and workaround as OP now too on a brand new system build. Left and right work as intended on top row. Up and down work as intended. Of the top row however, left/right causes a diagonal move up and the the left or right depending...going in and out of a title correct it. Also notice this oddly happens in my Movies and Television libraries but not Collections Hi, that's helpful, thanks. I'll take another look at it.
saj 14 Posted March 2, 2023 Posted March 2, 2023 I'll just add that I am seeing a similar problem. Most often, when I am trying to scroll right in a list of recorded TV shows, the cursor will move up instead of right. That's probably only because I do a lot more of that than in other media types. It is an intermittent problem. Without leaving the screen, it will work for a bit and then fail for a while and then start working again. When it's failing, it will fail consistently on both a programmable remote and a keyboard, so it's not the device doing the cursor movement that's causing it.
