CashMoney 94 Posted October 11, 2022 Posted October 11, 2022 (edited) Emby Theater 3.0.16 downloaded from Emby website. Weirdest issue I've ever seen. This apparently started happening "a few weeks ago"*. Navigation via 2 different htpc media remotes and a keyboard, behaviour is the same. From the Home screen, if I enter "TV Shows" or "Movies" or any media, I can navigate down, I can navigate up. If I navigate left or right, it goes up. If I enter a TV Show or Movie and come back out again, navigation is fine until I return to the home screen, and then navigation is up or down, with left and right going up. Hope that makes sense. Emby in a browser navigation works fine on the same PC via keyboard, wireless keyboard or 2 different remotes. Same peripherals work as expected in other non Emby related media apps. Things I've tried - I've uninstalled Emby Theater, removed the cache etc, reinstalled. Rebooted the PC. Removed the usb dongles for the remotes (usually only 1 remote plugged in, plugged in a 2nd different remote thinking the remote was the problem) incase they might interfere with the wireless keyboard or vice versa. Removed all wireless peripherals and used a wired keyboard only. Searched forums/Google for similar issues (not found anything). Anyone have any ideas? I've not got physical access to the machine* so If anyone does have an idea I'll have to probably try and fix it in a few days time. Unless it's a bug, which seems odd that no one else has the issue, I can't think of what else to try. *Not my machine, a friends. The machine in question is a PC running Windows 10 attached to TV, Emby Theater set to Desktop under display settings , server is on another machine in the same household. Emby Theater on server machine works as expected, just not on this second PC. Edited October 11, 2022 by CashMoney
Luke 42237 Posted October 11, 2022 Posted October 11, 2022 Hi, where exactly are you pressing left or right on? Can you please show a screenshot example? Thanks.
CashMoney 94 Posted October 11, 2022 Author Posted October 11, 2022 On a remote controls direction pad/keys and on a keyboards arrow keys. On the first image, I can navigate up and down, but pressing left or right on any peripheral the navigation goes up. If I enter into a show, like in the second image, and then back out/return to the screen in the first image I can navigate as normal. If I return to the home screen however, I'll have to repeat the above before I can navigate properly again. Navigation works normally on the home screen. This happens in any media/folder I choose from the home screen; TV Shows, Movies, Collections, Trailers, Photos. Hope that makes sense, as I say, very strange and no idea what else to try.
Luke 42237 Posted October 11, 2022 Posted October 11, 2022 24 minutes ago, CashMoney said: On a remote controls direction pad/keys and on a keyboards arrow keys. On the first image, I can navigate up and down, but pressing left or right on any peripheral the navigation goes up. If I enter into a show, like in the second image, and then back out/return to the screen in the first image I can navigate as normal. If I return to the home screen however, I'll have to repeat the above before I can navigate properly again. Navigation works normally on the home screen. This happens in any media/folder I choose from the home screen; TV Shows, Movies, Collections, Trailers, Photos. Hope that makes sense, as I say, very strange and no idea what else to try. Hi, in the first image, what currently has focus?
CashMoney 94 Posted October 11, 2022 Author Posted October 11, 2022 Those images are actually examples from my own system. On the system with the problem, if an item is in focus it's enlarged/prominent and looks perfectly normal afaik. I'll see if I can get images from the problem PC if you think it will help, but I don't have physical access all the time; it's a system I maintain for a friend. Afaict it doesn't look any different than my own.
Luke 42237 Posted October 11, 2022 Posted October 11, 2022 I don't necessarily need screenshots from the other machine. I just need to know what is currently highlighted at the time of pressing left. Thanks. 1
CashMoney 94 Posted October 12, 2022 Author Posted October 12, 2022 In the example first image, if I had The Boys highlighted, and pressed left on a peripheral, then the next highlighted item would be Around the World In 80 Days. If I had The Big Bang Theory highlighted, and pressed right on a peripheral, then the next highlighted item would be Altered Carbon. I should of described it better, it does actually move to the side, but jumps up 1 row as well.
Luke 42237 Posted October 12, 2022 Posted October 12, 2022 OK that's really strange. I've not seen that before. @FrostByte have you?
FrostByte 5452 Posted October 13, 2022 Posted October 13, 2022 1 hour ago, Luke said: OK that's really strange. I've not seen that before. @FrostByte have you? No, I cannot get that to happen using a kb as input
CashMoney 94 Posted October 13, 2022 Author Posted October 13, 2022 I should be able to get a good look next week, and if I can't figure it out, I'll switch it to Kodi (Emby for Kodi). I'll see if I can get some video of it, though I doubt it will help any Thanks guys 1
CashMoney 94 Posted November 3, 2022 Author Posted November 3, 2022 I've not had a chance to look at it since I posted (family issues, not sure when I'll get to look at it) but yes, afaik it's still happening.
MikeB111 60 Posted November 5, 2022 Posted November 5, 2022 Just thought I'd add to this, I'm not sure it's exactly the same but sounds similar enough that it could be related. I have noticed this only in the past several weeks. No change at all to my hardware or software setup in over a year (other than any auto updates to the Emby server or Emby Theater that might be happening in the background without action on my part). When I'm browsing recorded TV, sometimes it does not allow me to move in a direction. For example, there are six columns of shows shown in this library. Say I'm selected on the fourth across and want to move right one to the fifth in that row. Sometimes it won't let me do this, as I'm clicking right arrow (using a HTPC remote) the selected program does not change. I can move up or down or left, but not right. So I'll go up one or two rows, then over to the column with the show I want, then down to that show and I can watch it fine. But strange that it won't let me move directly to it in the first place. I know it's happened where it did not let me move right, I am not positive if it has not let me move left but that may have also happened. It is totally random, if I go back to the home screen and back in again it might work fine. I couldn't say if it's also happening in my movie library as I haven't been browsing there much recently, but definitely it has happened many times in my recorded TV library. Also, while testing it just now I noticed that the last row of programs only shows 4 shows instead of 6 in a full row. If I'm selected on that very last program in column 4 and arrow up, it moves me up one row but also left one row. If I go to the right it moves selection right, but then if I go up again it will move up and left. This is consistent. Anyways, seemed related to the original post perhaps, especially that it's only been happening for a couple of weeks now.
TC100 2 Posted November 22, 2022 Posted November 22, 2022 I'm getting a slightly different issue that feels related When I press up or down in my movies library in movies view it adds a left to every up and down command using either keyboard or remote control. Just pressing down goes down & left Just pressing up goes up & left It only occurs when navigating the 'boxart' portion, the menus are unaffected. Interestingly if I go to movies > folders then back to movies > movies (without returning to the main emby menu) it works correctly. I currently have it set to open movies > movies when opening my movies library from the main menu 1
Luke 42237 Posted November 23, 2022 Posted November 23, 2022 On 11/21/2022 at 8:31 PM, TC100 said: I'm getting a slightly different issue that feels related When I press up or down in my movies library in movies view it adds a left to every up and down command using either keyboard or remote control. Just pressing down goes down & left Just pressing up goes up & left It only occurs when navigating the 'boxart' portion, the menus are unaffected. Interestingly if I go to movies > folders then back to movies > movies (without returning to the main emby menu) it works correctly. I currently have it set to open movies > movies when opening my movies library from the main menu That's strange. @Happy2Play are you seeing that?
Happy2Play 9811 Posted November 23, 2022 Posted November 23, 2022 4 hours ago, Luke said: On 11/21/2022 at 5:31 PM, TC100 said: I'm getting a slightly different issue that feels related When I press up or down in my movies library in movies view it adds a left to every up and down command using either keyboard or remote control. Just pressing down goes down & left Just pressing up goes up & left It only occurs when navigating the 'boxart' portion, the menus are unaffected. Interestingly if I go to movies > folders then back to movies > movies (without returning to the main emby menu) it works correctly. I currently have it set to open movies > movies when opening my movies library from the main menu That's strange. @Happy2Play are you seeing that? Using the up and down arrows navigate up and down normally, unless this is a display mode thing? But did no see any issue in desktop or tv mode. 3.0.17 1
Luke 42237 Posted November 28, 2022 Posted November 28, 2022 On 11/21/2022 at 8:31 PM, TC100 said: I'm getting a slightly different issue that feels related When I press up or down in my movies library in movies view it adds a left to every up and down command using either keyboard or remote control. Just pressing down goes down & left Just pressing up goes up & left It only occurs when navigating the 'boxart' portion, the menus are unaffected. Interestingly if I go to movies > folders then back to movies > movies (without returning to the main emby menu) it works correctly. I currently have it set to open movies > movies when opening my movies library from the main menu Hi, can you try it again and see if it still occurs? Thanks.
CashMoney 94 Posted November 29, 2022 Author Posted November 29, 2022 As TC100, seeing the same here. Interestingly it's now doing it on the other pc as well. Both machines are running 3.0.17. It's random and intermittent.
AdamPhillips 8 Posted December 8, 2022 Posted December 8, 2022 I am having the same problem but only intermittently. Affects the keyboard and my Logitech Elite remote control. 1
MikeB111 60 Posted December 9, 2022 Posted December 9, 2022 Yep, I likewise can confirm that the problem is still there, also intermittent and seemingly random. 1
mitch2471 11 Posted December 10, 2022 Posted December 10, 2022 (edited) I also get this happening intermittently. It's a pain as not everyone in the family is tech savy so I always get called to sort it out. Normally a restart solves it, that or using the d-pad on a wireless keyboard. The tv guide shortcut also stopped working last night. Solved by a restart. Edited December 10, 2022 by mitch2471 1
TC100 2 Posted December 15, 2022 Posted December 15, 2022 Do you need any more information to help resolve this?
Luke 42237 Posted January 4, 2023 Posted January 4, 2023 On 12/15/2022 at 9:39 AM, TC100 said: Do you need any more information to help resolve this? Hi, I haven't been able to reproduce but am trying to chase it down. Thanks.
jellowe 8 Posted January 11, 2023 Posted January 11, 2023 This has been happening to me too for a few months. Intermittent. Sometimes I can go back to the home screen and enter a different section like if the issue is happening in TV I can go to movies and back into TV and the problem stops. Sometimes.
jbl77 3 Posted February 17, 2023 Posted February 17, 2023 (edited) Got the exact same issue and workaround as OP now too on a brand new system build. Left and right work as intended on top row. Up and down work as intended. Of the top row however, left/right causes a diagonal move up and the the left or right depending...going in and out of a title correct it. Also notice this oddly happens in my Movies and Television libraries but not Collections Edited February 17, 2023 by jbl77
