Sammy 791 Posted October 10, 2022 Posted October 10, 2022 I use noip with domain_name.hopto.org where domain_name is my specific domain name to resolve dns due to having a dynamic IP address. I've used this successfully for years but lately it isn't resolving which is effecting the use of LunaSea to connect to my arr's remotely. I checked at noip and it shows that the current IP address is active. I've tested by using domain_name.hopto.org:port and have not been successful connecting to the back end server. I've verified in my Unify Dream Machine that the ports are open and mapped correctly. I'm at my wit's end. Is this something that was a change in Windows Defender or other? Does anyone know? It is quite annoying!
Luke 42234 Posted October 11, 2022 Posted October 11, 2022 Hi, you may also want to check router dns settings.
Sammy 791 Posted October 12, 2022 Author Posted October 12, 2022 On 10/10/2022 at 6:58 PM, Luke said: Hi, you may also want to check router dns settings. I checked my dns settings and everything is fine. I can connect using a browser to domain_name.hopto.org:81 which is remote access for my BlueIris Security Cam software but cannot connect to the ports associated with my arr's using a browser. Very strange. 1
