kelepop 6 Posted October 9, 2022 Posted October 9, 2022 here attached the log @Luke dlna-subtitle-select-is-wrong.txt you can see that SubtitleStreamIndex=2 when request API but ,kodi got SubtitleStreamIndex=3 related:
Solution Luke 42237 Posted October 9, 2022 Solution Posted October 9, 2022 HI, what happens is we give Kodi all of the subtitle tracks, not just the selected ones. As far as I know there's no way to tell Kodi which track to pick. The only thing we could do is exclude the non-selected tracks, but then if we do that you won't be able to change tracks from within the menu in Kodi.
kelepop 6 Posted October 10, 2022 Author Posted October 10, 2022 (edited) 8 hours ago, Luke said: HI, what happens is we give Kodi all of the subtitle tracks, not just the selected ones. As far as I know there's no way to tell Kodi which track to pick. The only thing we could do is exclude the non-selected tracks, but then if we do that you won't be able to change tracks from within the menu in Kodi. I make some sniff with wireshark, that‘s true , subtitle selection will change the order of `<res protocolInfo="http-get:*:text/srt:*">` or `<res protocolInfo="http-get:*:text/ass:*">` the problem is : on the kodi side: kodi only load the first subtitle found in the <res protocolInfo>, even we passed all subtitle, I will try to make a patch to see if multi subtitle works, then I will open a PR to kodi along with the ASS support patch on the EMBY side: basically,it did the right thing,but,if I set subtitle to off,it still send kodi all the subtitle we have. Edited October 10, 2022 by kelepop
Luke 42237 Posted October 10, 2022 Posted October 10, 2022 Quote basically,it did the right thing,but,if I set subtitle to off,it still send kodi all the subtitle we have. Which I think makes sense otherwise you wouldn't be able to use the menu in Kodi to turn them back on.
kelepop 6 Posted October 16, 2022 Author Posted October 16, 2022 On 10/10/2022 at 12:40 PM, Luke said: Which I think makes sense otherwise you wouldn't be able to use the menu in Kodi to turn them back on. https://github.com/xbmc/xbmc/pull/22038 I pulled a new PR and waiting for any Futher steps of the kodi team once they accept it I will open a back port PR to kodi 19 also I'm glade to see a full functional DLNA subtitle selection on kodi 1
kelepop 6 Posted October 19, 2022 Author Posted October 19, 2022 On 10/17/2022 at 1:05 AM, Luke said: Excellent, thanks ! good news, The fix to KODI 20 was accepted bad news,they seems not not interested in backing port the fix to KODI 19 :( 1
