Mikexx 1 Posted October 8, 2022 Posted October 8, 2022 Everything use to work fine. As per title, recently many movies suffer from this issue, only a few don't and even then it's hit and miss after power cycling the TV box. I've also restarted the server. It runs fine on Chrome on a laptop. I have no idea what is causing this. Any ideas? I've attached an example log file. ffmpeg-transcode-99350065-7d08-4fe1-8f74-df0c0ba334f8_1.txt
Mikexx 1 Posted October 9, 2022 Author Posted October 9, 2022 58 minutes ago, Luke said: Hi, so you're using Chrome on a TV box? Yes, what should I use?
Luke 42240 Posted October 10, 2022 Posted October 10, 2022 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
Mikexx 1 Posted November 13, 2022 Author Posted November 13, 2022 On 10/10/2022 at 18:46, Luke said: Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks. Sorry for the late reply. I've been looking into this, and I've been looking for an Emby client, which I have failed to find. I'm not sure how this link helps? Is this not for the server? How is it used as a client? It seems this is quite a common problem; where the playback speed isn't as expected.
Luke 42240 Posted November 14, 2022 Posted November 14, 2022 22 hours ago, Mikexx said: Sorry for the late reply. I've been looking into this, and I've been looking for an Emby client, which I have failed to find. I'm not sure how this link helps? Is this not for the server? How is it used as a client? It seems this is quite a common problem; where the playback speed isn't as expected. Hi @Mikexx this link is for the Emby Android client. Can you please try that and let us know how it compares? Thanks !
Mikexx 1 Posted November 28, 2022 Author Posted November 28, 2022 On 14/11/2022 at 20:44, Luke said: Hi @Mikexx this link is for the Emby Android client. Can you please try that and let us know how it compares? Thanks ! This works fine, well for the first minute of course. If I go back to Chrome, then it runs again at double speed and no sound. What does this tell you?
Luke 42240 Posted November 28, 2022 Posted November 28, 2022 Have you updated to Emby Server 4.7.10? Has that helped?
Mikexx 1 Posted November 28, 2022 Author Posted November 28, 2022 18 minutes ago, Luke said: Have you updated to Emby Server 4.7.10? Has that helped? Thanks for the reply. I've just checked, it automatically updated to 4.7.10 a few days ago.
Mikexx 1 Posted December 4, 2022 Author Posted December 4, 2022 6 minutes ago, Luke said: Hi, has that helped? Sorry, no. I was trying to say that the client worked fine, but the Android browsers didn't with this version.
Luke 42240 Posted December 11, 2022 Posted December 11, 2022 What device and version of android is this on?
