mickle026 653 Posted October 7, 2022 Posted October 7, 2022 Hi, Im hoping someone can help. Im trying to understand how to initialise and use a list in a Struct (if it is possible) (I can do it in a class, im trying to fathom why I cannot do it in a struct, if its possible what im a doing wrong) public struct Person { public string Name; public List<string> Weblinks; public Person(string name,List<string> weblinks) { Name = name; Weblinks = weblinks; } } So when I try to add to the list Person NewPerson = new Person(); NewPerson.Weblinks.Add("www.somelink.htm"); ima am getting Quote System.NullReferenceException: 'Object reference not set to an instance of an object.' Now im maybe understanding this incorrectly, but i am understanding that I do not have an initialised list to add to. So I tried to create the list in the constructor and get the same problem public struct Person { public string Name; public List<string> Weblinks; public Person(string name,List<string> weblinks) { Name = name; weblinks = new List<string>(); Weblinks = weblinks; } } Quote System.NullReferenceException: 'Object reference not set to an instance of an object.' Same as this error in this image here: Does anyone know how to do this is a struct ? Many thanks
Luke 42193 Posted October 7, 2022 Posted October 7, 2022 You can't. Generally speaking for your emby plugin you'll pretty much never be creating structs.
mickle026 653 Posted October 7, 2022 Author Posted October 7, 2022 (edited) Thanks for the info, Im using a class for my code because of the need for a list, but its for a processing data function that doesnt communicate with emby itself. I just wanted to know if it were possible in the struct because the struct seems to be way faster than the class when itterating through lots of data. Now i have a lot more understanding in this area (still not perfect) its helping make my code much better , much shorter and faster as well But thank you. Edited October 7, 2022 by mickle026
Luke 42193 Posted October 7, 2022 Posted October 7, 2022 Quote I just wanted to know if it were possible in the struct because the struct seems to be way faster than the class when itterating through lots of data. Not to go off topic but I can assure that this isn't true. The real determining factor when iterating over a list is the actual work that you're doing as pass over each one. 1
TeamB 2440 Posted October 7, 2022 Posted October 7, 2022 (edited) 5 hours ago, mickle026 said: Person NewPerson = new Person(); NewPerson.Weblinks.Add("www.somelink.htm"); your calling the default constructor () not the constructor with the params so your class level instance objects are still null. sorry just saw that you were asking about structs, there is some info on struct constructors here https://www.tutorialsteacher.com/csharp/csharp-struct Edited October 7, 2022 by TeamB
TeamB 2440 Posted October 7, 2022 Posted October 7, 2022 2 hours ago, Luke said: Not to go off topic but I can assure that this isn't true. The real determining factor when iterating over a list is the actual work that you're doing as pass over each one. @mickle026 yes this, in most languages including c# class and struct are handled nearly exactly the same once they are constructed. How you iterate over the data is the key point. 1 1
Cheesegeezer 3104 Posted October 8, 2022 Posted October 8, 2022 15 hours ago, mickle026 said: Thanks Guys A little table for the differences. I never ever use Structs 1
mickle026 653 Posted October 8, 2022 Author Posted October 8, 2022 Thanks again guys. I feel that my knowledge has seriously stepped up a level since I'm starting to understand this and now even trying to understand the differences. Some of my amateur code has massively shrunk from 100's of lines to quite simply just a few. To me that's just - wow! That by Itself speaks volumes, but also the speed has gone from cumbersome average to fast, and that alone has made me feel more confident that I'm understanding this much better. All the help is very much appreciated
TeamB 2440 Posted October 8, 2022 Posted October 8, 2022 7 hours ago, Cheesegeezer said: A little table for the differences. I never ever use Structs can you post the source for this
BillOatman 596 Posted October 10, 2022 Posted October 10, 2022 (edited) On 10/8/2022 at 4:36 PM, TeamB said: can you post the source for this Formatted differently, but content looks the same here This seems to explain it pretty well to me. Quote As a rule of thumb, the majority of types in a framework should be classes. There are, however, some situations in which the characteristics of a value type make it more appropriate to use structs. CONSIDER defining a struct instead of a class if instances of the type are small and commonly short-lived or are commonly embedded in other objects. AVOID defining a struct unless the type has all of the following characteristics: It logically represents a single value, similar to primitive types (int, double, etc.). It has an instance size under 16 bytes. It is immutable. It will not have to be boxed frequently. In all other cases, you should define your types as classes. Edited October 10, 2022 by BillOatman
