taker1988 21 Posted October 7, 2022 Posted October 7, 2022 (edited) Hello, im running Emby Server 4.7.8.0 x64 on my Synology DS720+ NAS. Live-TV comes with a m3u-File which I am getting with telerising / my Zattoo Abo. EPG comes with easyEPG (Docker). With the newest Serverversion of Emby I am getting the wrong Thumbs displayed. Any tipps how i can fix this? taker-` Edited October 7, 2022 by taker1988
Luke 42237 Posted October 7, 2022 Posted October 7, 2022 Hi, have you checked the channel images coming from the xml guide data? They come from the data that you provide. The server does not have any other source for them.
taker1988 21 Posted October 7, 2022 Author Posted October 7, 2022 Yes, I checked that. And i think it should be ok?!
Solution Luke 42237 Posted October 7, 2022 Solution Posted October 7, 2022 Try deleting some of the existing images using the image editor and then refresh the guide data in the server.
