thegrunge 29 Posted October 6, 2022 Posted October 6, 2022 (edited) For a few days I have the firestick 4k max, and I noticed today that the sound is out of sync only when I listen to movies or tv series in emby, but not when I listen to live tv on emby. I then found that netflix, amazon video and youtube are okay. At the beginning I had synchronized the audio according to the series and films in emby, but I realized that for the other application it was problematic because obviously the synchronization was only good for emby movies and series . Suggestion? How to use an external player like vlc? To be in sync I have to adjust the sound of the firestick up 11 points. Edited October 6, 2022 by thegrunge
ebr 16337 Posted October 6, 2022 Posted October 6, 2022 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks. 1
thegrunge 29 Posted October 6, 2022 Author Posted October 6, 2022 @ebrI currently have the Amazon version I'm going to try Google's so, thank you! 1
thegrunge 29 Posted October 6, 2022 Author Posted October 6, 2022 @ebrIt's very good with the google application! 1 1
