Hispanico957 23 Posted October 5, 2022 Posted October 5, 2022 Before update in user settings i select to show genre and on tv Infact when enter for example in film (movie) or tv series genre are showed. Now after update server at rel. 4.7.8..0 also if in user settings never change in tv when select for example film (movie) or tv series are show movies or tv series and not more genre. This is an issue i think and hope is fixed soon! Thank Hispa I enclosed settings user and the result in tv
Luke 42186 Posted October 5, 2022 Posted October 5, 2022 HI there, what version of the android tv app do you have? Try updating to the latest version.
Happy2Play 9800 Posted October 5, 2022 Posted October 5, 2022 What client is that? If Roku you have to set landing tag within the app, enter library and hit star key.
Super957 24 Posted October 6, 2022 Posted October 6, 2022 (edited) 9 hours ago, Luke said: HI there, what version of the android tv app do you have? Try updating to the latest version. Hi thank i use on my FireTV and i have last version 2.079a from store. Instead when i am on server on my computer and select Film (movie), all is ok and genres appear after selecting Why this issue....and with version before of EmbyServer not happened Hispa Edited October 6, 2022 by Super957
Luke 42186 Posted October 6, 2022 Posted October 6, 2022 Can you check to see if an update is available for you? Thanks.
ebr 16307 Posted October 7, 2022 Posted October 7, 2022 Hi. When in that view, click the "cog" wheel and choose your default landing tab as "Genre". 1
