Luke 42242 Posted October 11, 2022 Posted October 11, 2022 Was the actual recorded video from the channel you were expecting?
Luke 42242 Posted October 12, 2022 Posted October 12, 2022 Can you get it to happen with another new recording? If you go and edit it after creating, what does it show there?
Rianscott 1 Posted October 12, 2022 Author Posted October 12, 2022 Weirdly BBC1 records BBC1 Dave records root (i'm not sure what root is)? Cbeebies records channel 4 CITV records channel 4 Pop records channel 4 when you edit, it still shows channel 4.
Luke 42242 Posted November 3, 2022 Posted November 3, 2022 @Rianscott are you still having an issue with this? We have not been able to reproduce.
Rianscott 1 Posted November 3, 2022 Author Posted November 3, 2022 Yes, nothing had changed. Portable and regular installation don't work correctly. Isn't it weird that it doesn't do it for you! Could it be something to do with the hdhomerun?
Luke 42242 Posted November 3, 2022 Posted November 3, 2022 What model is it, and is the firmware up to date?
Rianscott 1 Posted November 3, 2022 Author Posted November 3, 2022 Model: HDHR5-2DT connect duo yes the firmware is up to date
Luke 42242 Posted December 13, 2022 Posted December 13, 2022 Hi, are you still seeing this with Emby Server 4.7.10?
Rianscott 1 Posted December 14, 2022 Author Posted December 14, 2022 Yes! It works now! whatever was done, worked! I can start using it to manually record again. Thank you 1
